Do i have a Z28? (Trim Plate Info)
Old Jul 25, 2010 | 09:09 PM
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
I've owned my Camaro for about a month now. I'm pretty sure that it's a Sport Coupe, but i don't know if it's a Z28 or not. I have the Trim Plate info. Can any of you guys De cypher this crap for me?
C 07D 1FP87 L 190982
64B 75L 75U W
AR9
S 218422
I'm keeping my Fingers crossed
Old Jul 25, 2010 | 09:37 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
Re: Do i have a Z28? (Trim Plate Info)
if thats from the engine compartment, there its not really decypherable, it more for the factory than the consumer. if you have the rpo codes, which are usually found on the center console(make sure its the correct vin), there are in alphabetical order and should list Z28 as an option
Old Jul 25, 2010 | 09:42 PM
copyfixr's Avatar
Car: 88 Camaro
Engine: 2.8v6
Transmission: 700 R4
Grab the RPO decoder from here and put in all the codes from the console.
Old Jul 25, 2010 | 10:22 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
The car can only be a Sport Coupe or a Z28. It can't be both models. It is probably a Sport Coupe. Surefire way to tell would be by looking at the RPO codes like the others said. Or if you have the build sheet it will tell you. You could also tell appearance wise if it is a Z, as long as it hasn't been altered. Does the car have any Z-28 badges, or does it have ground effects?
Old Jul 25, 2010 | 10:23 PM
383 Power's Avatar
The Console Cover is missing.
Old Jul 25, 2010 | 10:25 PM
383 Power's Avatar
Nope, not badging at all and no ground effects. I guess it is pretty foolish of me to have thought it might have been a Z28. Even the Dash only says "Camaro" and that's it.
Old Jul 25, 2010 | 10:28 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
You never know, these cars have been around for a while and someone could have changed the apperance. But yeah I would bet it is a Sport Coupe. Still a Camaro though
Old Jul 25, 2010 | 10:41 PM
383 Power's Avatar
So, Then, Berlinetta would be the Base Model and Z28 would be the Top Model with Sport Coupe falling somewhere in between?
Old Jul 25, 2010 | 11:19 PM
hardon85's Avatar
In every year at least that I'm aware of the sport coupe was the base and this was before I was buying or following cars but I'm thinking they marketed the berlinetta as a luxury Camaro and the Z28 as the performance model. So I guess you could maybe say back then the berlinetta and Z28 were marketed as being somewhat equal but different Camaros as they both had different options that were not available on the other model and if you compare base prices if the berlinetta and Z28 had the same engine they were very close with the berlinetta sometimes costing more. But to answer your question the sport coupe was always the base or entry level camaro.
Old Jul 26, 2010 | 12:27 AM
383 Power's Avatar
Well, that's good news. That means that i can hack it up and modify it how i want to without destroying a classic trim package. I'll feel better about ripping out that tired old 305 and dropping in a pavement shredding 383! Maybe i'll even tub it out. Who knows? One thing that i couldn't ever truly understand is why a 4 Cylinder was actually ever an option. That HAD to be REALLY underpowered. Can you imagine a Corvette with a Four Banger? I can, however, see why it would be a good idea to restore one that is a 4-cyclinder because i can see those being rare.
Old Jul 26, 2010 | 09:48 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
later in about 85 the berlinetta took the place of the sport coupe, becoming the base model, although i forget the exact year
Old Jul 27, 2010 | 01:06 AM
1990z28's Avatar
Car: 1990 Z28 Camaro
Dident the C4 vette have a 4 banger as a option or am i just out of it.
Old Jul 27, 2010 | 03:56 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Holy cow guys!!! Do some research before throwing around information. The Sport Coupe is the base model and the Berlinetta was a Luxury edition of the Sport Coupe. The Z28 was the performance model. Also, 1982 cars did not have RPO stickers in the glove box. The tag under the hood will have Z28 on it if the car is a Z28. The Berlinetta never took the place of the base car.
Oh, the Corvette never had a 4 banger. The only vette to get that engine was the Chevette!!
Old Jul 27, 2010 | 04:25 PM
hardon85's Avatar
Thank you Scott none of this info is hard to find either, it's right here on the home page under tech data, I'm not claiming to be an expert either I just know where to find the answers.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
deracer
Apr 11, 2016 12:04 AM
bbernardo94
Aug 19, 2015 05:25 AM
