Front grill repair
Car: 99 T/A Firehawk, 1991 Formula
Engine: LS-1, LB9
Transmission: M6, M5
Axle/Gears: 3.42, 3.42
Front grill repair
My wife's 82 Trans Am has the louvered grills in the front bumper. Some of the mounting holes have pulled through, and I need some ideas on how to fix it. I figure epoxy is going to be in the equation somewhere, but would like to see what others have done.
Before you say "buy new ones" the car is painted a custom candy color, that painters are afraid to try and match.
thanks
thanks
Car: 1987 pontiac firebird
Engine: 6.5 turbo diesel
Transmission: t56
Axle/Gears: Ws6 axle
Re: Front grill repair
can you post pics of the damage if its not to bad just use washers. if its realy bad then epoxy.
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Try JB weld, I find it easier to sand down and get smooth if needed.
Engine: LS-1, LB9
Finally got some pics. The holes have pulled through. I thought about using a sleeve of plastic epoxied in for the crews to go through.
Engine: LS-1, LB9
Ok, for future reference here's what I did, and it worked pretty good.
I bought some nylon spacers from lowes, and ground them down on a grinder untill the fit the rough shape of the blown out hole, and was flush with the existing mounting surface.
I then used 15min setting epoxy to glue the inserts into the blown out holes.
After thet set, I used a different, more flexible epoxy to fill up all the cavitys in the grills.
This has produced a pretty solid set of grills.
