water on carpet passenger side
Old Aug 12, 2010 | 01:55 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
hi , i have a small leak on the passenger side carpet,,,not coolant ,,,heater core is new and it's clear rain water...where can it come from ..no t-tops...it will rust the floor...thanks.
Old Aug 12, 2010 | 05:59 PM
element114401's Avatar
Car: 1988 Chevy Camaro
Engine: 305 TBI
Axle/Gears: Posi
Re: water on carpet passenger side
Weatherstripping around the door?
Old Aug 12, 2010 | 06:55 PM
mooch1's Avatar
Transmission: T5 WC
it looks ok..you think water can get in from the door..it seems it is coming from the firewall...
Old Aug 12, 2010 | 09:00 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Check underneath the mesh panel that surrounds your wipers, and see if it is clogged with leaves, and debris. If it is, it could rust and let water in through the firewall.
Old Aug 13, 2010 | 08:38 AM
mooch1's Avatar
Transmission: T5 WC
hi , tried that ..looks clean,..
Old Aug 15, 2010 | 01:10 AM
84z350crate's Avatar
Car: 84 Z28
same problem, cant find where it comes from. I ran a hose around the door and windshield area and no luck .
Old Aug 15, 2010 | 02:33 AM
Awesome-X's Avatar
Car: 87 Camaro
Take it to the car wash, sit in it and have someone hit it with the high pressure hose. Be sure to have it on rinse and not soap. That should help you a bit.
Old Aug 15, 2010 | 06:50 AM
mooch1's Avatar
Transmission: T5 WC
maybe i'll try that,,,i did the same thing with the garden hose,,,no water came in...weird!
Old Aug 15, 2010 | 10:13 PM
polaris91's Avatar
Car: 88 camaro z28
i had holes in my wheelwells that were also going straight through the firewall filling my new carpet with water and causing a rust hole in my floor. check the firewall from the inside where the seam sealer is thats where mine rotted
redmaroz
Apr 25, 2017 07:14 AM
corlando52
Interior Parts Wanted
Aug 24, 2015 11:32 AM
Cameeeero
Aug 20, 2015 03:06 AM
Street Lethal
Aug 14, 2015 08:25 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
