What size cowl hood to get?
Old Aug 15, 2010 | 07:09 PM
Piston454's Avatar
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
hi i am looking at getting a cowl hood for my car because i need the clearance for the throttle body space i am putting on there. i am looking at a 4 inch, is that too much? or what size should i get? thanks
Old Aug 15, 2010 | 07:30 PM
MassD's Avatar
Car: 1984 Trans Am
Axle/Gears: 3:73
Re: What size cowl hood to get?
That is a 4 in cowl on a camaro, i think they look sick if they have a nice race motor sitting under them, i would 2 or 3 inch if you have a stock motor and 4 inch if you plan on putting some muscle under there and you really need the clearance. The 4 inch is for racing.
Old Aug 15, 2010 | 07:32 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
all you added was a 1" throttle spacer? a 2" hood would be more than enough, if you even need that.
big cowl hoods are stupid on a car that doesn't need them to cover something. It is also a factor of local laws, in NJ, you are limited to 2.5"? or it can be considered obstruction. Probably not an issue if you dont drive the car every day, but if you DD the car, you will probably get pulled over eventually for it.
Old Aug 15, 2010 | 07:53 PM
Piston454's Avatar
Car: 1990 RS Camaro
well ya i have a nice motor in it now. i am guessing it has close to 350 hp. and it looks really nice that's why i think it would be okay to put a nice tall cowl on it. and i also need some more clearance. but i dont want something to short, i want it to stick out.
Old Aug 16, 2010 | 03:50 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I wouldnt go above 3 inches... that's what I have. Nice room under the hood but still decent visibility. And it's not TOO ostentatious.
Old Aug 17, 2010 | 01:20 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
This is a all steel 2in. Goodmark cowl hood. It measures 3in. at the rear vent.
Old Aug 17, 2010 | 10:44 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
x2 for the goodmark cowl hood.
i have one myself, although its still in primer. very nice fit and function.
made a big difference in throttle response too. my 350HO was very happy to have all the extra ambient air.
Old Aug 17, 2010 | 10:58 AM
joepackersrock's Avatar
Car: 1991 RS Camaro
Engine: 400 Smallblock
That is one nice hood and one nice car, but I agree the 4 in stick up is huge and just doesn't look right for anything but a drag car.
Old Aug 18, 2010 | 12:30 PM
khulsebus's Avatar
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
this is a 3" harwood glass bolt-on hood that i bought for my '91 rs in 2004. it fit the air cleaner well and wasn't too tall to make forward visibility suffer too bad.
Old Aug 18, 2010 | 08:23 PM
mh82camaro's Avatar
Car: 82 camaro berlinetta (z28clone)
Engine: gmpp 350,edelbrock,msd,k&n
Transmission: stage 2 maddog 700r4
Axle/Gears: motive gear 4.10/ eaton posi
i have a harwood 3 in cowl
Hotrodboba400
Dec 10, 2019 07:07 PM
Linson
Sep 21, 2015 01:08 PM
timonator
Sep 10, 2015 07:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
