bolt on hood or pin on?
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
what is the difference between a bolt on cowl hood and a pin on? i heard that the pin on hood allows the cowl to come back closer to the windshield, is that true?
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
Re: bolt on hood or pin on?
bolt on uses factory bolts and opens up like stock.. the pin up hood uses hood pins to hold the car down and you generally have to take the whole hood off... it will not raise up like stock because it doesnt use any hood struts or the other features... personally a bolt on hood is much better
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
pin on hoods are a PITA, and require a lot of work to get on the car. Get a bolt on
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
