Hoods Acting Badly
Old Aug 17, 2010 | 07:15 PM
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
Hoods Acting Badly
My Hood doesn't lift or close evenly. It stays up when lifted, but both sides do NOT raise or lower at the same time. Is this a problem with a weak shock? How hard is it to change the shocks?
Old Aug 17, 2010 | 07:25 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Hoods Acting Badly
sounds like one shocks bad its super easy to change the hood shocks. . .
Old Aug 17, 2010 | 07:27 PM
383 Power's Avatar
thanks, Do i have to remove the Hood Mount to change these? Lord knows i don't like Aligning the hood. I'll have to do it eventually when i change engines, but i don't want to have to mess with it before then.
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
I experienced that problem and in my case it was the hood strut's. It's very easy to replace just get a broom stick or something to prop the hood up on the side your going to switch the shock out on get a flat head screw driver and work the top and bottom clip off till it comes out and the new one should just push in and your done. That's how I did it I don't know if it's the correct way but it worked for me.
Old Aug 17, 2010 | 07:31 PM
383 Power's Avatar
alright, i'll order the parts. Thanks guys. I suppose i should replace them both for good measure. they seem Cheap enough.
Old Aug 17, 2010 | 07:34 PM
Car: 1988 camaro
Engine: cammed 3.1
Yeah if you replace just one then the new one will have more work to do as the other one is already worn out and you will have the same problem.
Old Aug 18, 2010 | 08:45 PM
donnis618's Avatar
Car: 1984 camaro Z28
Engine: 355
Make sure your hood is actually not coming apart. I thought my shock was bad on the pass. side, but its actually my hood (at the rear)!!! Saving for 'glass replacement but they are high as hell.
Old Aug 19, 2010 | 06:35 AM
383 Power's Avatar
Thank you, i will check that.
Frozer!!!
Jan 19, 2024 04:55 PM
Cornholio7979
Sep 20, 2018 02:31 AM
LittleFranks
Aug 20, 2015 03:55 PM
perZ
Aug 15, 2015 01:17 PM
3rdgenparts
Aug 6, 2015 09:03 AM
