Why did the primer do this?? pic
Old Aug 21, 2010 | 08:35 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
Transmission: HD 700r4 B&M Stage2 SK
so im preppign my car for paint and i sanded down the a hood i picked up and it had a few little gouges in it so i filled it and let it dry, sanded it down and primed in like i have a couples times before but now in the spots where the filler is its like the primers not quite adhereing to it right ? or is it just different being ona different material?
you guys figure i can shoot the paint on this? or what should i do here thnx
Old Aug 21, 2010 | 10:24 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
Re: Why did the primer do this?? pic
Maybe the filler wasn't completely dry?
Old Aug 21, 2010 | 10:26 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
well its been like 2 days now and ive tryed going over it with more primer and the same thing still?!?!
Old Aug 21, 2010 | 10:31 PM
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
Maybe your Mixture was wrong. Maybe there wasn't enough Hardener.
Old Aug 21, 2010 | 10:39 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
sigh..... its so weird tho its like absorbing the primer or like...pushing it off but its still going on nicely . just very strange, think im boned here boys
Old Aug 21, 2010 | 10:46 PM
trocustoms's Avatar
Car: 1988 GTA Black on Black Hardtop
Engine: 383 miniram/ Ebl
Transmission: 700r4/Performabuilt/3000 Stall
Axle/Gears: 9 bolt / 3.27
Take a closer pic. cant tell anything from the posted pic
Old Aug 21, 2010 | 10:49 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
Old Aug 21, 2010 | 11:14 PM
trocustoms's Avatar
Thats not much better. Im assuming the lite coloring is where your filler is? If so it looks as though your primer is soaking in to your filler. Are you thinning your primer to much? Lacquer based? urethane based? Spray can?
Old Aug 21, 2010 | 11:16 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
spray can :\
Old Aug 21, 2010 | 11:21 PM
trocustoms's Avatar
If its only doing it where your filler is its probably soaking in from a cheaper primer. Usually to thin. Let it dry over night and lightly sand with 180 and reprime. It should start to build after 2 or 3 coats.
Old Aug 21, 2010 | 11:23 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
ive hit it twice since i did it like 2 days ago now, ill try hittin it with the sand paper tomorrow though and hope for resuslts.
Old Aug 21, 2010 | 11:28 PM
trocustoms's Avatar
Is the primer laying down nice and smooth? Or is it not adhering
Old Aug 21, 2010 | 11:32 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
it seemed like it was laying down on it alright when i ran my hand over it when it was dry but when i sprayed a coat on it, i watched it like soak in
Old Aug 21, 2010 | 11:36 PM
trocustoms's Avatar
Its either soaking in or something is bleeding through. Use a differnt primer tomorrow after this has cured overnite. Let me know tomorrow
Old Aug 23, 2010 | 01:50 PM
Big Cleatus's Avatar
Car: '84 Trans Am
Engine: 350 Carb
Axle/Gears: Stock but subject to change.
I had the same problem using rattle can primer. It's because rattle can is too thinned out. What I did was really goober it on there really thick. It had some runs, but goober it on the spot, sand it down smooth and flat, then finish up with a light coat. That should do it.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
TexasFormula
Sep 30, 2015 06:36 PM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
