Looking for weatherstripping 86 Camaro
Old Sep 9, 2010 | 03:03 PM
Steven6282's Avatar
Car: 1986 Z28 Camaro
Engine: 350 with .440" lopey cam
Transmission: 6spd T56
Axle/Gears: Detroit Truetrac with 3.73 gears
Hello,
Hoping someone can help me out. I'm looking for complete weatherstripping for my new project car
1986 Chevrolet Camaro Z28 V8 305 with T-Tops
I want to replace all the seals, t-tops, doors, the little rubber pieces on the top of the doors that the window slides between, trunk. Including the big rubber pieces on the ends of the t-tops that overhange the window.
My problem as show above, I don't know the names of these seals and don't know what to buy. I saw the 1AAuto posting on here for a kit that has everything (according to the red in the picture) except for the piece the window slides through, however their price is 450 dollars. Near as I can tell Hawks Third Gen, has the same GM kit for 260 dollars except it is backordered. I don't want to pay an extra 190 dollars for something unnecessarily.
I was looking on summitracing.com here:
http://www.summitracing.com/search/P...k%7cAsc&page=1
But again, I'm not sure which items I need to buy to get all the seals I need. I read someone elses post on here saying they got a complete set from summitracing for 200 shipped, I'm guessing prices could have changed but if I can get a kit for anywhere close to 200 rather than 450 that would be great.
If anyone can help me out I would be very grateful!
By the way you can see a picture of my camaro here: as you can see in the picture it is in desperate need of some seals, especially the on overhanging the window at the end of the t-top!
Old Sep 9, 2010 | 03:50 PM
91 zeee's Avatar
Car: 1991 Z-28
Engine: 383 TPI
Re: Looking for weatherstripping 86 Camaro
you might want to check out some of the the posts on this board.... everything I have seen says buy GM. It is way more expensive, but it seems most people who did not buy it wished they had. I just had my car painted, the body shop owner said to get GM if it was available. He does a lot of restorations and had experience with oem and aftermarket and there was no doubt in his mind that oem weatherstripping has not yet been matched by the aftermarket suppliers.
Old Sep 9, 2010 | 09:19 PM
Steven6282's Avatar
Well I'd be happy to look into GM, but I still need to know where to buy it and what exactly to buy. I have no clue what to even ask for if I were to call GM, all the seals seem to have different names.
If GM isn't to expensive I will buy it, but if they are I'll buy aftermarket, I don't really care as long as it doesn't leak. I'm not even sure if mine leak now, I just got the car over the weekend and it has not rained yet, the main thing is how ugly the overhang looks and the missing piece from the driver side that the window roles up through. Right now if it were to rain water would get inside the door very easily and I imagine that could very easily lead to rust in the door and shorted out power window motors etc.
Old Sep 9, 2010 | 09:29 PM
91 zeee's Avatar
Car: 1991 Z-28
Engine: 383 TPI
the best way to make sure you get the right stuff from GM is to call your local dealer with the last 8 digits of your VIN #. They will then pull up your EXACT car and make sure you get all the weatherstrip you need (they even have a parts diagram for you if you need it).
It will be way more expensive (mine was somewhere around $1200)-- but it will fit just like it did from the factory. I cannot say for sure because I did not use aftermarket stuff, but from what I have read the aftermarket stuff does not go back in very easy and doest not fit as well as the original stuff. Check around though, maybe you will find out something different.
Old Sep 9, 2010 | 09:49 PM
bdle's Avatar
Car: 1988 Camaro IROCZ
Axle/Gears: Stock
I got my t-top weatherstriping from classic industries, its oem and i havent had any problems with it at all. And they should have everything else that your looking for. Just giving out a suggestion, good luck.
Old Sep 10, 2010 | 08:18 AM
Steven6282's Avatar
Are these the correct parts to replace the ugly looking pieces that overhang the window at the end of the t-tops?
http://www.1aauto.com/1A/Weatherstri...ampaign=1ATony
And is this the piece that the window rolls up between on the outside?
http://www.hawksthirdgenparts.com/ou...dfirebird.aspx
Old Sep 10, 2010 | 08:21 AM
1Aauto's Avatar
Former Sponsor
HI Steve,
If you have any questions or need help, you can buzz me here in the office or PM me if you want.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
