how much power can my frame take?
Old Sep 18, 2010 | 01:10 AM
akel91rs's Avatar
I have a 91 rs with t-tops it has a 305 throttle body I've had it for a little over a year and I want to do some engine mods (a 350/400 camshaft aluminum heads tpi or multiport and a new intake) but my step-dad and grandpa said that it would twist the frame I was just seeing what you guys think I'm new to this stuff and want other opinions
Old Sep 18, 2010 | 01:40 AM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Re: how much power can my frame take?
Simply put....
Subframe connectors aren't a bad idea.
It will feel lke a new car!!!
http://www.umiperformance.com/catalo...roducts_id=127
The UMI pics are at the bottom of the page...
You can use our search engine at the top of the page or Google to see more pics & Read the different threads and see what others say...
By the way.... I haven't twisted my frame yet
Old Sep 18, 2010 | 01:44 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
I don't think anything would be permanently distorted
with those engine plans,but chassis flex is one of the
3rd gen's worst features and ANY thirdgen will really
benefit from having the chassis reinforced to correct
this fault:subframe connectors and a 3pt. strut tower
brace at the minimum....
Beleve me they drive so much nicer when rigid
(when i got my '82 with 86000 mi it wasn't too bad
and a brand new '90 F/B i drove was very tight,but
due to bad design and less than optimal assembly
methods,flex can creep in over the years..)
Old Sep 18, 2010 | 02:56 AM
akel91rs's Avatar
Thanks but will the subframe connectors get in the way of cut back exhaust?
Old Sep 18, 2010 | 08:39 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Nope...
Old Sep 20, 2010 | 03:03 PM
akel91rs's Avatar
Cool thanks for the advice guys
Old Sep 20, 2010 | 08:07 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
Subframe connectors can get it way of exhaust. I have dual catalytic converter option and they conflict with UMI connectors I bought. Some people can get them to fit. Mine might fit but would be really tight. My outside stock exhaust pipe is partially crushed so they could fit it up against the inside pipe. I think spohn or bmr makes SFC's that fit dual cat cars. SFC section near cats is a smaller round tube that is bent up. Doesn't look as strong as box versions like UMI's. Not saying it can't be done. Just might be another modifying project if you do. I will have to remove cats and exhaust to install SFC's. Can't wait to get SFC's installed though
You won't have a problem with your car though.
1992 Trans Am
May 10, 2023 07:19 PM
neilb
Oct 4, 2018 12:36 AM
gta90
Sep 15, 2015 04:00 PM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
