not sure which hood i wanna get
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
i'm kind of stuck on 3.
i want a 82-83 functional Z28 hood because of just that, and the fact that the hood is lighter.
i wouldn't mine a fiberglass cowl hood, nothing too major, 2 1/2 inches or so, then with this hood, i'd be able to get straight racing stripes.
and then theres the sasquatch hood i've always yearned for the daytona iroc hood.
which one do you guys think?
i dont think they make reproduction of the 82-83 Z28s, do they?
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Re: not sure which hood i wanna get
Yeah personally as cool as the cowl and IROC hoods are I would go with the functional Z-28 hood. Just because it would free up 50-100 pounds (depending on what you have now) and the fact that it is functional will help keep the engine from coming close to overheating.
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
If you can find an true fiberglass/functional early z hood in good conditon, most defintly grab it or theres an member on here (do an search on fibeglass iroc hood) that he makes and sells fiberglass iroc hoods and carbon fiber iroc hoods (he runs i think around 600 for the fiberglass with the glass weight around 30lbs and the carbon around 20lb)
I messaged him about doing what needs to be done to make them functional (not the louver parts though, just the actual metal) and he said he possibly could do it so defintly shoot him an PM.
But anyhow there defintly an great way to loose weight and early z and iroc hoods always look great!
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
If you have decent fabbing skills,it's pretty easy to make
the non-functional carb SMC hoods functional-just build
an airbox underneath to mate to the aircleaner,remove
the fake louvers,cut out the material behind...
-did this with my '82 back when it was still carb,worked
great but without any flaps and open all the time,had
some carb icing problems under certain cold weather
conditions.
conditions.
yeah even though i like the cowl hoods and everything, i want it to still look like a Z28, other than the badges.
do you know how much the functional ones go for? or even where i can find a fiberglass Z28 hood?
i actually thought about making mine, somewhat functional.
i would take the 2 louvers off, then cut the area open, then put foam or weather stripping on the louvers, and just take them out on sunny days.
conditions.
conditions.
Car: '82 z28
Engine: L83 5.7
Never looked at one close,but probably could make a
steel z28 hood functional using the same method
When i made my SMC hood functional i did make some
grilles for the openings-out of the honeycomb pattern
material found under a fiero engine cover,expanded
metal material cut from a used truck air filter might
look good too.
When i modified my air cleaner,i got a cover with raised
center from a caprice and cut off the outer part past
where the filter seals,then rigged the the airbox to
seal against the air cleaner base with the hood closed
(was really looking for an'80-81 z28 air cleaner but
could not find one-that would have been perfect!)
BTW this setup really let out the quadrajet intake
noise nice
look good too.
noise nice
Car: 1983 z-28
Engine: 305 4 barrel
Transmission: 5 speed
Axle/Gears: 373
hi ,I got a Fiberglass, or SMC (sheet molded composite) which is a fiberglass like material. its from a 83 z-28plates blocking the flap holes.hood without the functional hood flaps
for sale I live in Minnesota its in nice shape .for a fair amount mail me at aschulz61@yahoo.com
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
