T/A headlight doesn't stop openening / closing when it should...?
Old Sep 20, 2010 | 10:50 PM
88PontiacT/A's Avatar
Car: 88 T/A. TOTALLED!! (not by me)
Engine: TPI 5.0
Transmission: 700r4 Auto
Axle/Gears: 2.73 posi
Whenever I turn on the headlights, they both come on and open but the right side light trys to keep opening. It Acts like the motor doesn't want to stop, until it "pops", falls down about an inch, and goes back up about 7-8 times, and then it will finally stop. Seems like it's trying to "over-extend" itself. Does the same thing when it closes. Is there some adjustment that needs to be made that will correct this problem? Or does it just mean that the bushings are junk and it needs new ones?
Thanks,
John C.
Old Sep 21, 2010 | 01:41 PM
Engine: TPI 5.0
Re: T/A headlight doesn't stop openening / closing when it should...?
ttt
Old Sep 21, 2010 | 03:08 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
The nylon pegs between the nylon gear and the metal shaft for the lift lever are toast. Go to a store and get some cheap 3/8" ball bearings. 3 are needed per motor, should cost about $2 if you find some.
Old Sep 21, 2010 | 05:15 PM
AmorgetRS's Avatar
Another option is to buy the bushings from Top Down Solutions (www.top-downsolutions.com) and you'll get everything you need to fix them.
http://www.top-downsolutions.com/pro...products_id=87
Old Sep 21, 2010 | 09:21 PM
Engine: TPI 5.0
Yeah, that's what i figured...thanks, I appreciate the info.
John C.
Old Sep 21, 2010 | 09:29 PM
92FBirdVert's Avatar
Car: 1992 Pontiac Firebird Convertible
Engine: 5.0 TBI
sounds like it needs bushings
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
beast94
Aug 20, 2015 06:44 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
