3RD GEN LAMBO DOORS
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
3RD GEN LAMBO DOORS
ANYBODY DONE LAMBO DOORS ON A 82-92 ? MY DOORS ARE OFF FOR BUSHING REPAIRS. THIS IS THE BEST TIME TO DO IT. SO FAR I CANT FIND A TRUE BOLT ON KIT. IM NOT GONNA CUT OR WELD MY FRAME SO BOLT ON IS THE ONLY OPTION. ANYBODY SEEN OR DONE A KIT THAT IS A BOLT ON WITH MINIMAL FENDER MODIFICATION AND NO CUTTING / WELDING ON THE FRAME OR DOORS ?
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
Re: 3RD GEN LAMBO DOORS
Dude you don't need All Caps...
And aparently you didn't search hard enough, or at all..?
all i did was search on google 1982-1992 Camaro door kits.
THis was first link; They're going to cost ye 1299$ plus shipping and time/work to put them on
http://lambodoorspal.com/lambodoors/...sort=2a&page=1
Chevy Lambo Doors Description: Lambo doors conversion kit for CHEVY CAMARO 1982-1992 (ALL Models). This Authentic Vertical Doors, Inc. kit will enable you to easily modify your vehicle and attain the look you desire! Direct "Bolt On" hinge kit. Mounts to Factory Bolt Pattern. Made in USA from Domestic Hardened Steel. Completely Reversible
MOD'S REQUIRED
High quality CHEVY CAMARO Lambo doors / vertical doors kit. This Lambo doors kit is made specifically for your 1982-1992 CHEVY CAMARO. The kit comes with 2 door hinges, 2 shocks, all the mounting hardware, and installation instructions.
MOD'S REQUIRED
CHECKED EVERYWHERE. LOOKS LIKE VERTICAL DOORS IS THE ONLY BOLT ON.
ANYBODY KNOW OF ANY OTHER DOOR KITS PRICED AROUND 300.00-400.00 THAT DONT NEED CUTTING / WELDING LET ME KNOW...
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
http://www.bestlambodoors.com/servle...3-84-85/Detail
279 plus shipping and
with the previous poster you having cap's lock on looks like your yelling at everyone and that sure isn't a way to get help now is it
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
Caps Lock - Are you ready to unleash the F*$king Fury?
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
IF I FIND OUT ANYMORE ILL POST IT HERE.
Car: 1988 Camaro IROC T-Top
Engine: 350ci TPI
Transmission: TH-350
Axle/Gears: 4.11 Posi
Car: 1985 Camaro Z28
Engine: 5.7 LSX
Transmission: Performabuilt 4L60E
Axle/Gears: Strange 12-bolt 3.73
Interesting... I think they would look pretty cool if done correctly. I personally wouldnt put them on mine tho. I like mine opening regularly, but those would definately look cool on the right car. So far, the sample pics that those two websites had were pretty ugly cars, but on a nicer third gen, it just might work!
WHEN I KNOW EXACTLY WHAT IM GETTING INTO I MAY TRY A KIT. UNITL THEN IM GONNA FIX MY REGULAR DOORS AND DEAL WITH THE REST OF THE CAR.
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
https://www.thirdgen.org/forums/sout...members-4.html Couldn't get the pic to copy so here's a link, it's on the bottom of the page. What do you think they would look like on mine? I'm on the fence personally. Just don't want junk parts.
SO FAR IT LOOKS LIKE THE KITS REQUIRE CUTTING HINGES OFF OF DOORS AND/OR WELDING- DRILLING AND POSSIBLE INNER FENDER TRIMMING. NO ONE SEEMS TO KNOW EXACTLY WHAT IS REQUIRED. I EMAILED A LOT OF VENDORS AND THEY SENT ME INSTRUCTIONS FOR A TOYOTA CELICA. WTF ?! ALOT OF TROUBLE THAT IS NOT EASILY REVERSIBLE. GOOD CHANCE TO DO MORE HARM THAN GOOD. WHEN YOU WANT TO SELL YOUR CAR IT WONT BE FACTORY ANYMORE.
Car: 1991 Firebird Black
Engine: 3.1
Transmission: Automatic
I bookmarked both links I might try this. Just to make it that unseen mod till you get out. LOL.
3.1L is not impressive but at least the doors might be cool
Beside that it look like swinging straight up might make tight parking spots easier to get out.
Beside that it look like swinging straight up might make tight parking spots easier to get out. Senior Member
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
I THOUGHT ABOUT THE TIGHT PARKING SPOT ADVANTAGE AND MISSING CURBS IF YOUR CAR IS LOWERED. IM RUNNING INTO SO MUCH RESISTANCE AND UNKNOWNS IM HOLDING OFF UNTIL SOMEBODY THAT HAS DONE IT CAN TELL ME WHAT IM GETTING INTO.
Engine: 3.1
(or buy the kit and see how it looks I am sure you could resell it here if not liking it)
DONT TEMPT ME.... Junior Member
Engine: 3.1
When I recover from my own doings after the first of the year I think I am going to take the plunge. Just to say I did it. The only thing I haven't seen is how the windows work on this but heck for a couple hundred dollars and the ability to say "I did it".
I'd do it, just to watch the boys around here whine about how they can't.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
All caps, showing you're not smart enough to know how to use a keyboard.... good luck installing 'lambo doors'.
Car: 2000 Camaro SS/86 Iroc/89 Iroc(x2)
Transmission: 6 Speed
Axle/Gears: 4.10
IMO a lambo kit isn't for an F-body, everything will work as it's supposed to... door locks, windows etc, but too much cutting fender work involved. I have a friend who has it on his car and it's not worth it. It causes too much damage, and doesn't look that good. Just my .02
THATS WHAT I FIGURED. DAMAGE. IM NOT GOOD WITH DAMAGE. NO ONE WILL WANT A CAR THATS NOT FACTORY WITH DAMAGE.
Axle/Gears: 4.10
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
There was a 5th gen at the beach bash with lambo's on it. It looked pretty good but they did have to cut out the reinforcements at the rear of the fender to make room for the hinges. Seemed to work well but they were basically new. Be interesting how they work 4 or 5 years down the road.
Car: Too many cars
Car: Too many cars
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Must be junk.
