My turn with the RUST
Old Oct 1, 2010 | 07:05 PM
jer4251's Avatar
Car: They all sit.
Engine: LS1, LB9, LB9, L98, LT1, LT4, LT4
Transmission: A4, T5, T5, A4, A4, T56, TR6060
Car has been sitting for 6 years basically untouched. junk/animals/weather have taken a toll on the metal in some areas. Need to know what im looking at, i havent removed the doors or fenders, but is this area fixable?
the actual floor pans are clean and rust free, the water sat up in the front corner slowly rotting away the metal. i know its going to take some work, but can it be patched insted of replacing the entire floorpan? need input, i will save this car, but need to know where to start
Old Oct 1, 2010 | 08:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: My turn with the RUST
thats a common spot for rust/rot. Any body rot can be patched without replacing the entire panel. If you have good fab skills and can weld, it will take some work and time, but is totally fixable. You can make a patch from scratch, or try to find a doner car to cut the area from and patch it in. That may be a little tricky though.
Old Oct 1, 2010 | 08:59 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Mine is rusted in roughly the same area on both sides. You may want to pull the fender and the GFX piece to get at the other side of the rust. Cut it out and patch it. It may require 2 or more pieces of metal (make a kind of floor pan sandwich), but it should be doable.
deracer
Apr 11, 2016 12:04 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
Exxon Limited
Aug 9, 2015 08:13 PM
Fronzizzle
Aug 9, 2015 01:15 PM
