Please help, how to remove rear bumper cover.
Old Oct 5, 2010 | 03:36 AM
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
Well straight to the point, I got an nice inch around scooped dent in my rear bumper cover and I would like to try my best to remove it, and it looks like I will have to remove the rear bumper cover and I need to know what I need to do.
I realize pushing the dent back out will cracked the paint, well I would just like the dent out. So please, I need directions on doing this. Thanks.
Old Oct 5, 2010 | 04:11 AM
fadedirocz28's Avatar
Car: 1985 Camaro Iroc-Z
Engine: LB9
Re: Please help, how to remove rear bumper cover.
https://www.thirdgen.org/forums/body...ll-do-you.html
https://www.thirdgen.org/forums/body...per-cover.html
Did you see these threads? i've never had to do it so im not sure how accurate it is.
Do you plan on heating it up a bit and trying to bend it out? I know its urethane so you cant just bang the dent back out
Old Oct 5, 2010 | 04:18 AM
Engine: 305TPI
Thanks for the link, I didnt even think of searching before I made the thread as I was so frusturated. So basically if i remove those plastic tabs the cover should at the least be movable enough so I can get to the dent better?
About the heat, Would i just heat the back of the dent tell it pushes back out or would I also apply the ice to it like other dents? Thanks.
Old Oct 5, 2010 | 04:26 AM
Engine: LB9
I tried to fix a nose cover one time by heating it (in the headlight bucket was bowed up), i could never get it as flat as factory, but i bet with a block of wood and a little more patience i could of gotten it pretty close.
I'm not a body guy and i really don't wanna tell you to do something that I'm not 100% positive will work you know? if you try it before someone else chimes in, start off slow. not a lot of heat, just enough to get it moving. i think the more heat you use the better the chance you mess up the paint.
When i heated mine, it didn't move on its own, i had to try and shape it back myself.
and on the the ice, I've seen where u heat and cool quickly and it causes a dent to pop out, but that's on metal body parts, these are urethane so I'm not sure if that works.
Old Oct 5, 2010 | 04:30 AM
Engine: 305TPI
thanks for your help, i'll try the heat thing once i can get decently to my problem area on the cover, hopefully it'll work, thanks.
Old Oct 5, 2010 | 04:31 AM
Engine: LB9
And btw, https://www.thirdgen.org/forums/body...ver-saved.html
On this thread a guy says to heat in small areas, then cool it off with a wet rag. Closest I've found to directions, Good luck. You should snap some before and after pictures
Old Oct 8, 2010 | 09:18 PM
Engine: 305TPI
well to my suprise, the dent actually got itself out! sorry for the hassle.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
3rdgenparts
Aug 8, 2015 07:09 PM
