hatch problem need help
Old Oct 10, 2010 | 12:06 AM
aljohnsonii's Avatar
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
i have two questions
one does anyone know the part number or where i can get the plastic shims in the pull down motor housing i have the small ones but need the wide ones
does anyone know if the back hatch can be adjusted the spolier hangs past my tail light about a half an inch and i have adjusted the glass but it still hangs over can you adjust the actual metal piece forward
Old Oct 10, 2010 | 12:17 AM
qcworm's Avatar
Car: 1987 IROC Z-28
Engine: L-B9
Transmission: 700R-4
Re: hatch problem need help
you can adjust the metal piece on the window but it isnt east, i have slotted theholes at the top where the hatch bolts to the car, i have had 7 cars with the same problem
Old Oct 10, 2010 | 12:22 AM
qcworm's Avatar
Car: 1987 IROC Z-28
Engine: L-B9
you can adjust the metal part up on the glass but i have also had to slot the holes at he
Old Oct 10, 2010 | 07:11 AM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Plastic guides are available from TDS or Hawks. Here's a link to help you get your hatch alignedhttps://www.thirdgen.org/hatchalign
Old Oct 10, 2010 | 12:08 PM
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
i found them on there but i need a oem part number
Old Oct 10, 2010 | 12:30 PM
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Don't think they are available from GM. Maybe part of assembly. Here's a link to what you need I think. http://www.top-downsolutions.com/pro...products_id=48
Old Oct 11, 2010 | 12:04 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The guides were never available from GM as a replacement part. Which is why I stepped in to supply an aftermarket replacement version. Thanks GM!
Lon Salgren
Old Oct 11, 2010 | 02:47 PM
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
i bought them about a year ago and i cant find them i got them from the dealer here locally for about a $1 a piece and i cant find the part number to order them again
Street Lethal
Apr 30, 2019 12:14 PM
hydrolic144
Sep 8, 2015 06:55 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
