Paint prep
Old Oct 13, 2010 | 05:02 PM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Paint prep
Hey guys, I'm about to start the body work on my 84 trans am that is factory red with silver on the bottom. I would like to paint it red again so I don't have to fight the door jams. Should I strip it down to bare metal to get ready for paint? Is there a better tool for removing paint than a wire wheel on a grinder?
Dustin
Old Oct 13, 2010 | 06:42 PM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Re: Paint prep
I would never remove undamaged paint. Unless you have a LOT of rust, or the grey e-coat is peeling, you don't really want to strip it.
One thing to watch for is small pits from surface rust. They will cover up but come back to haunt you. Good luck, I'll help you as much as possible but you really need someone to SEE the car that knows what to do.
Old Oct 13, 2010 | 07:09 PM
1badeagle's Avatar
Engine: 370 LSX
Re: Paint prep
I have a small 2"x3" pitted spot above the passanger side rear wheel well. Is there a way to make it look good without a new patch? Other than that the cars pretty solid. I've sprayed a bunch of times, but never on a car that I had to do the body work on.
Drone358
Sep 21, 2015 08:54 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
TheExaminer
Sep 6, 2015 11:40 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
