Rattle can primer
Old Oct 23, 2010 | 12:52 PM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Rattle can primer
Hey guys, I'm getting ready to start blasting my bird down to bare metal and need a good primer in a rattle can. I'm doing the car in pieces so I don't want to get my spray gun out a bun of different times. Would etching primer be good enough to hold me off till spring when I can sand it real quick and shoot it with some high build primer and then paint it? Let me know if you know of anything.
Dustin
Old Oct 23, 2010 | 01:13 PM
mdihotmale's Avatar
Car: 1989 irocz,87irocz,05 tacoma trd
Engine: 5.7's,5.0.4.0
Transmission: a4, an sixspeed
Re: Rattle can primer
yes that will be fine, but it will take alot of cans to do the whole car, but yea its pretty much the same as spray gun just alot less , it will hold up fine
Old Oct 23, 2010 | 01:38 PM
1badeagle's Avatar
Engine: 370 LSX
That's what I figured but seems like other forums are serious haters on spray primer.....
Old Oct 23, 2010 | 08:42 PM
mdihotmale's Avatar
well its not the best idea, if it were me id just grab the gun a blast a quick coat on it, but cans will do fine, long as your ganna sand it down again, give her hell bud
Old Oct 23, 2010 | 08:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
not sure if you are currently using the car, or what, but primer wont protect the body from rusting, so if you are going to be driving the car between now and when its painted, keep that in mind.
Old Oct 24, 2010 | 01:43 AM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
As 86TA said primer won't protect you from rust. It's actually porous and will retain moisture. I don't think you should have a problem since it's only gonna be til spring but quick shot of clear coat would be the safest route.
Old Oct 24, 2010 | 03:49 AM
1badeagle's Avatar
Engine: 370 LSX
Yea it's not getting drove, it's sitting inside my pole barn. I'm media blasting it in sections before I got to work in the mornings, so I only get a few hours to work a day. It won't be driven at all. What brand and kind do you guys reccomnd?
Old Oct 24, 2010 | 04:02 AM
Brock Lee's Avatar
Car: 1991 Firebird Formula
I would buy a cheap gun dedicated to primer. You get a whole lot more finish for your money using a gun. The spray cans are thinned with a ton of solvents and takes a bit longer to cure. In a 16 oz can, you may get the equivalent of 3-4 ounces of gun finish as the primer is so watered down and the can also has propellant in it.
Also, you should be using an epoxy primer for the first coat on bare metal.
Old Oct 24, 2010 | 04:05 AM
puma1552's Avatar
Primer accelerates rust.
Old Oct 24, 2010 | 06:55 PM
Delo93's Avatar
Car: 89 Camaro RS
Engine: 5.0L TBI
use epoxy primer in a can, that will keep you protected... upol makes some good stuff, but its not cheap
Old Oct 25, 2010 | 12:27 PM
1badeagle's Avatar
Engine: 370 LSX
Well I ended up getting some 2k epoxy primer so I can hoot it out of my gun. Not really the direction I wanted to go, but I guess you gotta do things you really don't want to when it comes to a third gen!!!
Dustin
Old Oct 25, 2010 | 10:05 PM
Delo93's Avatar
Car: 89 Camaro RS
Engine: 5.0L TBI
cool, what kind did you get?
Old Oct 25, 2010 | 10:12 PM
Delo93's Avatar
Car: 89 Camaro RS
Engine: 5.0L TBI
As long as you have your parts/car sitting inside they will be fine sitting in bare metal, just hit everything quick with 180 on a da, and scuff with a scotchbrite pad before your ready to prime, and your good to go.
Old Oct 25, 2010 | 10:14 PM
1badeagle's Avatar
Engine: 370 LSX
Ooo, I can't remember the brand, but it came from house of color in my town. So I expect it's a real good brand. I have 83$ in it all.
Dustin
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
jrdturbo
Mar 31, 2016 02:58 PM
GouldyGTR
Sep 7, 2015 09:05 PM
Ian Irvine
Sep 4, 2015 08:08 AM
mustangman65_79
Aug 8, 2015 12:07 PM
