3rd brakelight
Old Nov 14, 2010 | 09:38 PM
camjam's Avatar
3rd brakelight
have '86 Camaro Z28 (I believe) how do u tell an IROC from a Z28...all my emblems were gone when I purchased the car...whats the diff between a Z28 IROC and a plain 'ole IROC?...it has a T-top...I read where ONLY 86's had an EXTERNALLY mounded 3rd brake light on the leading edge of the back window...mine has it mounded INTERNALLY!!??..back window has not been changed/replaced..any info would b greatly appreciated (new to this forum and 3rd Gen)...camjam
Old Nov 14, 2010 | 09:48 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Re: 3rd brakelight
If you car really is an 86, then the rear hatch must have been replaced as they only had the third brake light mounted internally in 91-92. AS far as I know, there was only the Iroc-Z28 or Iroc-Z. Either that or just the Z28. Check your VIN and your RPO codes.
Old Nov 14, 2010 | 10:02 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: 3rd brakelight
https://www.thirdgen.org/1986-chevy-camaro
In 86 it was mounted up high in the back glass.It was moved to the spoiler,if equipped,in 87.Follow the link or read the tech data on the main page.
Old Nov 14, 2010 | 10:07 PM
chevydrvr's Avatar
Re: 3rd brakelight
That's true it was mounted on the glass in 86 but on the outside. It then moved to the spoiler in 87 until 91 where it moved to the inside of the glass.
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
Dragonsys
Sep 25, 2015 03:51 PM
