Need dimensions for heritage stripes (92)
Old Nov 24, 2010 | 11:31 AM
speed.chad's Avatar
I have a vinyl cutter and can lay out and cut the stripes, but i don't have a car to reference. Can someone with a set of original stripes please measure the width of the stripe, distance from front edge of hood, width and offset of the border pinstripe, and how far apart the stripes are from each other. Total width from outside edge to outside edge would be nice too. Thanks
Old Nov 24, 2010 | 11:46 AM
mightymaro94's Avatar
Re: Need dimensions for heritage stripes (92)
off topic but what kind of cutter do you have? i been lookin to purchase one and cant make up my mind... im thinking about a 28 inch would be the right size for me but i dnt know what brand to look for
Old Nov 24, 2010 | 11:50 AM
speed.chad's Avatar
I've got a 24" Zen Cut Green, from uscutter.com
Old Nov 25, 2010 | 07:13 PM
speed.chad's Avatar
anyone?
Old Nov 25, 2010 | 09:38 PM
jer4251's Avatar
Car: They all sit.
Engine: LS1, LB9, LB9, L98, LT1, LT4, LT4
Transmission: A4, T5, T5, A4, A4, T56, TR6060
they are not the same size the entire length, from the hood blisters back they are wider. If i remember, ill measure mine tomorrow.
Old Nov 25, 2010 | 09:46 PM
speed.chad's Avatar
just the stripe itself, front and back. I have a flat hood so I can just taper them as needed. then the width of the pinstripe itself, and how far from the main stripe it is. Length from back of hood to front edge of stripe, and distance between two main stripes
Old Nov 25, 2010 | 09:59 PM
jer4251's Avatar
Car: They all sit.
I'll try and hook you up with all i can tomorrow. with pics.
Old Nov 28, 2010 | 11:44 AM
speed.chad's Avatar
any luck?
Old Nov 29, 2010 | 12:35 PM
jer4251's Avatar
Car: They all sit.
got some numbers, to make an exact copy will be a pain in the butt. their not even anywhere on the car, always going skinny to wider. this should give you a good idea. If i missed something, ill try and get it for you. My stripes are a little worn, so i had to use the good spots to get a better measurement. just follow the link to the full size pics, i have some measurements in the descriptions.
http://s75.photobucket.com/albums/i2...2%20Z28%20Z03/
the stripes are 2 7/8" apart. not including the pinstripes.
the pinstripes are 1/4" thick and 1/4" gap between them and the stripes.
Old Nov 29, 2010 | 02:10 PM
speed.chad's Avatar
Thanks, that should get me what I need. My car has a flat hood so a gradual taper will work for me.
Elephantismo
Feb 13, 2019 12:51 AM
starliner
Feb 9, 2016 08:18 PM
z28venezuela
Oct 24, 2015 08:15 PM
Gordonr1973
Sep 29, 2015 11:59 AM
89bird2.8
Sep 25, 2015 09:21 AM
