Sunken Door
Old Dec 19, 2010 | 07:03 AM
fireburn84's Avatar
Car: 1984 Firebird S/E
Engine: 5.0L 305 V8
Sunken Door
The front of my driver side door is no longer flush with the body. It's now recessed about a half inch or so in comparison to the front body panel. What would cause this?
Old Dec 19, 2010 | 12:28 PM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Re: Sunken Door
Look under your car, just behind the front wheel. There should be a metal flange with a bolt in it. The flange should be pointed straight down. Many times, either with a floor jack, lift, speed bump. these flanges get mashed. When they do it usually kicks the fender out. Straighten the flange out and the fender should come back in.
Old Dec 22, 2010 | 08:56 PM
fireburn84's Avatar
Engine: 5.0L 305 V8
Re: Sunken Door
Thanks for the help. My car's in storage now but I'll give your suggestion a try in the spring.
Old Dec 22, 2010 | 09:08 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Re: Sunken Door
Same thing is wrong with mine except for I cant find the metal flange on my car for some reason, I dont even see it on the other side! Anyone have a pic?
Old Dec 23, 2010 | 10:24 AM
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Re: Sunken Door
I'll get ya a pic if you really need it but it's just to the inside of the ground effects. Bolt in fender should be parallel with ground. More than likely it's mashed up to the point that it's hard to find.
Old Dec 23, 2010 | 11:40 AM
Re: Sunken Door
So you dont need to remove the GFX to see it?
Old Dec 23, 2010 | 12:07 PM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
Re: Sunken Door
No it should be viewable if u have the car jacked up slightly and laying on ur back looking straight up
Old Dec 23, 2010 | 01:14 PM
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Re: Sunken Door
Yep what he said.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
