91 Camaro RS Grant installation kit
Old Dec 30, 2010 | 04:46 PM
cherryvalley's Avatar
Car: '91 Camaro RS
Engine: 3.1 V6
I am wondering if this installation kit will fit my camaro. I know the wheel im getting will fit the kit and need to see if this install kit will fit my car. Thanks.
http://www.oreillyauto.com/site/c/de...6.oap?pt=03460
Old Dec 31, 2010 | 04:19 AM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
Re: 91 Camaro RS Grant installation kit
if this is the earlier install kit for f bodys prior to the airbags then yes. do a search on here for airbag removal. be careful and take your time. after al thats out of the way its a simple install. i had a grant whell on my 91 then replaced it with a restored factory leather wheel.
Old Dec 31, 2010 | 12:38 PM
Car: '91 Camaro RS
Engine: 3.1 V6
its just a normal installation kit. you see, my airbag was blown in an accident, so instead of hooking everything back up [laziness] i just bought the installation and wheel and hope it will all be good.
Old Dec 31, 2010 | 04:08 PM
Slash's Avatar
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
lol the back of the installation kit box says the years/models it will fit. Same way how u figure the steering wheel will fit the car (its marked on back of box)
Old Dec 31, 2010 | 04:39 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
it will fit , but with some work/mods. . the major item is to trim 1/4" from the steering column collar all the way around . i used a small hobby workers saw on mine . just take it real slow & easy or you WILL mess up the column collar . i don't think that would an easy item to fix/repair and still look good . good luck .
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
dhonda200
Aug 11, 2015 11:50 PM
drathaar907
Aug 6, 2015 04:20 PM
