passenger door???
Old Jan 6, 2011 | 01:01 PM
racerquinny's Avatar
Car: 91' camaro rs and an 87' trans am
Engine: stang eater..slower ones. lolololol
Transmission: 700r4-camaro t5-trans am
Axle/Gears: stock :(
passenger door???
i installed my passenger door last night. and the latch on the door is stuck closed....it will not latch onto the bolt on inside of car. its not wired yet..so could i wire it and it will unlatch????
thank guys
Old Jan 6, 2011 | 07:34 PM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Re: passenger door???
When you say stuck closed, I assume you mean the latch is locked. Unlock door, pull handle then open the latch with your fingers or screwdriver. I've seen them get tripped while wiping the jambs out many times.
Old Jan 6, 2011 | 09:16 PM
yeah i will have to try that tomorrow.
dont mind the lubricant haha
Old Jan 7, 2011 | 11:20 AM
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Yep it's latched. pull the handle to release it and it should come open with a little help.
Old Jan 7, 2011 | 12:49 PM
ok cool thanks white gold
Old Jan 7, 2011 | 12:56 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Beat me to it. Ditto. I had the same problem a couple of months ago when I put my passenger door on. I have seen many pictures of nicely painted cars (third gens) where there is that fender gap between the door and fender. With a little hard work you can get it to line up. I am still trying on mine.
Kevin
Old Jan 8, 2011 | 04:21 PM
yeah it worked...it was just really cold and late when i got the dooe on and tried to line everything up. so maybe i will work on it tomorrow. im going to try and get it painted or taped off atleast. then get my hood hinge straight.....passenger hood hinge doesnt line up. its bent ahah
gta892000
Aug 11, 2019 11:16 AM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
m00n420
Sep 11, 2015 02:39 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
Fronzizzle
Sep 8, 2015 12:10 PM
