How do you keep water out of your Ram Air/SS hood
Old Jan 11, 2011 | 11:19 AM
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Post up pics or ideas of how you keep water from getting in your hood when its raining. Foam inserts, block off plates, whatever you got lets see em.
Old Jan 11, 2011 | 11:37 AM
85projectZ28's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 LSX
Transmission: Performabuilt 4L60E
Axle/Gears: Strange 12-bolt 3.73
Re: How do you keep water out of your Ram Air/SS hood
sorry bro. cant do pics or ideas. the rain always wins. i never took mine out in the rain because of the ram air set-up i made. i wont ever be able to! good thing i got a daily driver!
but im not sure how it would work with blocking it of or putting dams? i think that would defeat the purpose of having that slot...
Old Jan 11, 2011 | 12:12 PM
Axle/Gears: stock
I was thinkin more for carb setups, the way you have your ram air setup up I see it being a pretty big difference in air flow.
Also I would only have it on while its raining. My two vehicles are my GSXR and my Camaro, so when its cold and rainy the camaro is the best one to take out lol
Old Jan 16, 2011 | 05:03 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Currently on my ss hood,with a carb setup,I carry a roll of duct tape,and if I get caught in the rain,I put some of that over the inlet.Sounds a bit ghetto,but I dont usually drive it in the rain,if I can avoid it.One of these days I'll make a block of plate for it.
Alicat.
Old Jan 16, 2011 | 11:30 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Should compare pretty even as with those hood I got about as much ducting till it get to the engine and with my 68 Firebird hood scoops Ive drive year round for many years, rain, snow, shine no problems.
I have used some screen before on and off, but it was only to keep leaves and acron's out of the intake.
Old Dec 14, 2012 | 07:49 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Hmm. Is it possible to suck in water in the rain?
Old Dec 14, 2012 | 08:52 PM
1983Chimaera's Avatar
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
You have to use a water separator plate and sump. Basically the air will have to pass thru some sort of vertical S curve, meant to trap the water and allow it to run off and collect in a low spot. The low spot has sump holes on either side to allow the water space to drain, while the air continues on. The ram air effect will still function, as the entire S curve will pressurize. You can also add a screen to catch larger particulate and debris. Look at some of the old factory designs to get ideas for what you need to create.
Old Dec 14, 2012 | 09:44 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
I have never had a problem yet, with the scoop open. I do not dd the camaro
Hotrodboba400
Dec 10, 2019 07:07 PM
Stangski09
Nov 14, 2015 01:27 PM
R3500
Sep 8, 2015 10:12 PM
09ave
Sep 7, 2015 06:03 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
