Is there a trick to removing the cowl screen?
Old Jan 31, 2011 | 12:44 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
I need to take my cowl screen off, but it is hung up on the passenger side wiper that goes through it. I need to remove the screen to unbolt the wiper, but I need to unbolt the wiper to be able to remove the screen?!?!
Old Jan 31, 2011 | 01:25 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Is there a trick to removing the cowl screen?
The wiper comes off without removing the screen. At the base of the wiper arm, there is what looks like a tab - pry that tab outward away from the wiper arm with a flathead screwdriver. As you pry it out, the 'teeth' will release from the splined wiper motor shaft, and the wiper arm will lift off the shaft.
On the cowl - it's held in with plastic tabs that 'pop' into holes on the body. You need to carefully pry upwards on the cowl and it'll pop off. BUT ... be careful not to get the edge or corner of your prying instrument under the lip of the windshield - the least bit of 'prying' under the lip of the windshield will crack the entire windshield (ask me how I know :duh.
Old Jan 31, 2011 | 08:26 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Got it off! Big hole inside, right over the driver's feet. Patch panel time!
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
hdis2002
Sep 8, 2015 02:52 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
