sub frame connectors and floor replacement
Old Feb 16, 2011 | 07:32 AM
andy74's Avatar
Car: 1988 gta carbed 383
Engine: small block 4bbl
Axle/Gears: 3.27 g80
i have a very rusty 84 z 28 that i am parting out,when i get done stripping it,i was/am considering building the body into a drag car,the problem beingthe floor is fullof rust holes.my thought was to weld in some subframe connectors,and build a sheet metal floor,with only a seat and roll cage-any ideas as to if this will work?i plan on just por 15 then bondoing the quarters,the doors and fenders are easily fixable,so its just a matter of stiffening the car,may even weld the passenger door shut!
Old Feb 23, 2011 | 09:55 AM
CHJ37's Avatar
Car: 1991 Chevy Camaro
Engine: Chevy 305 bored .30 over
Re: sub frame connectors and floor replacement
my buddy did that. except welding the passenger door. hes putting a (396) 414 in it but hasnt run the car yet. looks goood and stiff though
Old Feb 23, 2011 | 08:57 PM
iluvmy91camaro's Avatar
Car: 1991 Chevy Camaro RS w/t-tops
Engine: BBC 396 .090 over (414)
Transmission: LS1 T-56
Axle/Gears: Shortened Ford 9, 3.25, discs, posi
What I did is cut out the enitre trunk area. went to summit bought a universal 4 link set of frame rails, 4 link kit etc. and made the back of the car a custom fit. I also bout and 8 point cage and tied the cage and frame rails in at a few points. (also you need the crossmember too) Then I bought Comp Engineering weld in connectors and tied those into the frame rails and floor etc. This all probably doesnt make sense but I can post pics and explain them if you want. The car is so stiff now.. its rediculous
Frozer!!!
Jan 19, 2024 04:55 PM
gta90
Sep 15, 2015 04:00 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
