Quarter panel destroyed
Old Mar 8, 2011 | 08:07 PM
jamesw343's Avatar
Car: 1986,1988,1989 IROC
Engine: ?,L98,383 L98
Transmission: ?,700r4,700r4
Axle/Gears: ?,3.27,3.45
Recently picked up 1989 for cheap that has been hit hard on passenger door.Hit destroyed door and pushed door jam back so I'm going to try to fix it up.I've got a good donor car for replacement parts so need to know what is the best way to remove quarter panel and what is the best way to reinstall,I've got air tools, garage, and a Miller mig welder
Old Mar 9, 2011 | 03:19 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Re: Quarter panel destroyed
If it got into the jam that bad....it's going to be put on the rack to be pulled....or it will never be right.
Old Mar 9, 2011 | 04:46 PM
jamesw343's Avatar
I'm going to take it to the frame shop to have checked and pulled staight but what is the best way to remove good quarter from donor,drill out all spot welds or just cut off with a cutoff wheel.What is best way to do it so I don't screw up the good quarter and it will go back on correctly?
Old Mar 11, 2011 | 11:57 PM
1986maro's Avatar
Car: 86 Camaro Iroc-z
Engine: Lb9 (305 TPI)
Transmission: 700r4w/ 2500 stall shift kit
Axle/Gears: quick performance ford 9 3:70
try drilling out the spot welds and using a cut off wheel to cut the top. cut it big so you can trim later. take your time and do it right while its on the car its a lot easier to do it on the car than trimming it off the car.
FormulasOnly
Jul 23, 2018 08:47 AM
jrdturbo
Mar 31, 2016 02:58 PM
LC2 TECH
Oct 13, 2015 11:53 PM
kkirch15
Sep 30, 2015 04:44 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
