install of new fog lights
Old Mar 20, 2011 | 11:13 AM
Phx89Iroc's Avatar
Car: 1989 IrocZ Convertable
Engine: 350 5.7
Transmission: AUTO 4 SPD, THM 700 R4
Axle/Gears: AXLE REAR, 2.73 RATIO
my car is torn apart because its getting restored on the outside. the front bumper mechanism is removed, the black inner section where the got lights go is removed, etc.. if i get new fog lamps (after market probably), how hard will it be to replace them after the car is back together? I'm not sure if i need the body shop to install them for me while the front is already disassembled.
thanks.
Old Mar 20, 2011 | 11:21 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: install of new fog lights
Easy to install, even with car completely put back together.
Old Mar 20, 2011 | 11:30 AM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
It isnt hard at all if you know what your doing (just a couple of bolts, some of which you will need an extension). I actually just replaced the bulbs in mine last week (took an hour and a half because I didnt have anyway to jack the car up to reach the bolts easier) however the fog lights still dont work. If you have a Chilton manual it describes it in there but if you need me to I can list the steps on here.
Old Mar 20, 2011 | 12:37 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
If you have the stock fog lights with the stock mounting hardware its pretty straight forward.If you get aftermarket as you said,there is no telling how you will get them to mount.
I bought a set of fog lights of of ebay that only needed minor modifications to mount to the stock mounting brackets.They came with a relay,wires,switch and everything needed to get them running.I dont recall the seller or any details really because it was in 2005.He sold them as a replacement but said they needed to be modified.He also had pics showing them on his car.
If you want to search for some on ebay you can but there is no telling what you will get if they dont specify them for our cars.You can see a pic of them on my car in my VBgarage.
Old Oct 14, 2011 | 03:26 PM
budget builder's Avatar
Car: 91RS
Engine: carb'd 357 vortec
i know this is an old thread but somone pls list the steps.
Old Oct 14, 2011 | 09:55 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
http://www.youtube.com/watch?v=WxWLVGfGKlo
jaridjohn
Jul 8, 2024 03:49 PM
TheExaminer
Aug 26, 2015 04:59 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
