Why do I need a cowl vent??
Old Mar 22, 2011 | 10:25 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Sounds like a silly question, but I have rust through my firewall from a blocked cowl drain and the pain in the butt issue of repairing the damage on such a hard to reach area got me to thinking...
The cowl vent/drain area is only there to allow access to the wiper system, correct? Why not make a removable, sealable panel that caps the cowl drain. It is removable for wiper system service and sealed to prevent water access. Too simple? Am I missing something?
Old Mar 22, 2011 | 11:12 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Why do I need a cowl vent??
IIRC, it's part of the flow through ventilation system, along with the body pillar exhaust valve (vent at the door).
EDIT. The following is from my owner's manual: "With the side windows closed, the flow through ventilation system provides outside air flow into the front air inlet grilles, though the vehicle and out the rear air exhaust valves."
JamesC
Old Mar 22, 2011 | 11:55 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
But how does it get from the cowl drain through the vehicle? And if the cowl drains are clear, you have an open system anyway...
Old Mar 22, 2011 | 12:03 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
The AC system/blower motor draws air in through the cowl vent, blows it in through your dash vents, then those little black plastic vents in your door jamb, just above the striker, let the air pressure from inside out. Without the door jam vents, the air pressure inside would build up until the blower motor was strong enough to pull air in through the cowl vent.
In other words? Don't seal it shut.
Old Mar 22, 2011 | 12:29 PM
JamesC's Avatar
Here's a bit more from the manual:
Your vehicle has a flow through ventilation system that provides a supply of outside "ram" air into the vehicle when it is moving. When the vehicle is not in motion you can get a steady flow of outside air into the car with the heater or air conditioning blower running.
JamesC
Old Mar 25, 2011 | 10:13 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
JamesC
Does the cowl mater if you no longer have a heating or cooling system?
Old Mar 25, 2011 | 11:38 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
I would think if the cowl is open at the top and water drains out the bottom behind the fenders, blocking the top would not cut off airflow, since if it is part of a flow through air system, it would just draw air through the drains at the bottom...
Old Mar 25, 2011 | 02:54 PM
nosajwols's Avatar
Car: 82 Z28
Transmission: TH350 for now
Not likely very much since the drains are not in a high pressure area (like the cowl).
Old Mar 26, 2011 | 08:24 PM
david chambers's Avatar
Car: 1986 iroc Z-28
Engine: "LB-9" TPI 305
Transmission: 700-R-4
Axle/Gears: corporate 2:73-1
you are missing a factory assembly manual
Old Mar 26, 2011 | 09:46 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
What do you mean Dave?
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
Fanatic1074
Oct 2, 2015 03:47 PM
