1991 z28 hood
Car: 1991 z28
Axle/Gears: 2.77 posi
1991 z28 hood
i just bought a 1991 z28 305 tpi and the guy i bought the car from put an older hood on the car to replace the 6 inch cowl induction that was on the car when he got it. the hood on the car now is the wrong color but it is from an older iroc, it has the black insert fins in the middle. i was wondering if there was any way to take the black things out and put in the correct metal inserts or do i need to get a different hood? thanks
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: 1991 z28 hood
The black plastic louvers are just held on with nuts from the underside of the hood. You'll have to take off the insulation pad to get to the nuts, and you can put the hood blisters on in their place.
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: 1991 z28 hood
Yep, same hood. The blisters can be hard/expensive to find, as are the louvers. Make sure you dont remove the louvers til you have the blisters in-hand.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
diana227vegas
Jul 8, 2016 12:27 AM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
