diff between 91 and 90 firebird body
Old Mar 23, 2011 | 06:23 PM
weesel72's Avatar
Car: 85 trans am
Engine: 5.0 carbed
Transmission: TH700R4
Axle/Gears: 9 bolt
Ok, so im a little stupid about the difference bewtween the 90 and 91 firebird bodies? I just bought a 1991 firebird formula project, first pontiac. Ive always owned chevy novas. I need to find body parts like the rear hatch/spoiler to start, and i was hoping someone could "school me" on what body parts are inter-changeable? Any help would be GREATLY appreciated!!! Maybe a little help on good spots to find used and new body parts. I live in northeast ohio. Thanks in advance!!!
Old Mar 23, 2011 | 06:29 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Re: diff between 91 and 90 firebird body
82-92 are interchangable, not sure when but some years had third brake light in the rear hatch, hard to come by i think
Old Mar 23, 2011 | 06:38 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
for sites check thirdgenranch or hawks. lots of new and used parts
Old Mar 23, 2011 | 07:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
3rd gen birds have 3 different styles, 82-84, 85-90, and 91-92. If you are looking for the proper rear hatch for a 91, you need to get a 91-92 only hatch, since they are the only years to have that specific spoiler. any other year, 82-92 hatch will fit, but some have 3rd brake lights under the glass, on the glass, or not at all.
they physical body is the same, but the ground effects setups changed over the years, so the holes in the fenders are a bit different from style to style, the bumper covers are different ove the years, and the headlights have at least 3 different styles, all very close, but different in small ways.
It would be best to get parts from a 91-92 car, to eliminate some of the headache
any pics of the new project?
as for your engine confusion. the 8th digit of the vin will tell you what engine the car came with. "8" is the 350 tpi, "f" is the 305 tpi, "e" is the 305 tbi.
Old Mar 24, 2011 | 12:04 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
ebay can be your friend for this project. That rear spoiler (wing) can be really hard to find. I've been searching for one for 3 years and havent found a good one yet (Price, condition, shipping, etc.) Good luck!
Old Mar 24, 2011 | 05:52 AM
weesel72's Avatar
Car: 85 trans am
Engine: 5.0 carbed
Axle/Gears: 9 bolt
Thanks for all the help! The 8th vin engine code is "E" so i do know it came with the 305, just not sure if it's the original engine yet, or not? I do know that the 350, did not come in cars with t-tops, just need to pull the engine out to see what it is. The rear hatch that came with the car has the third brake light on top in the glass with the wrong spoiler, so i guess ill be hunting that down, yeah. As far as pics, not yet, just bought. I personnally always leave the body work for next to last, starting with the engine, tranny,frt end,rearend/suspension, body, then finally interior. Maybe ill put up some pics soon of the "before". This car did come with 4 black GTA wheels w/all the center caps and are in 95% shape that i will be looking to sell, just need to see what they're worth. Thanks again, its nice to know there is a place to go where i can get some answers!
Old Mar 24, 2011 | 06:25 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Pull the engine out to see what it is? Just check the stamping on block, and see if matches the last 8 digit of the VIN. Stamping is located on the head gasket surface, passenger side, at the front, facing up.
Old Mar 24, 2011 | 10:34 AM
weesel72's Avatar
Car: 85 trans am
Engine: 5.0 carbed
Axle/Gears: 9 bolt
Let me re-phrase, im pulling the engine anyhow, but thank you for the help, i appreciate it!
Old Oct 8, 2011 | 08:21 AM
weesel72's Avatar
Car: 85 trans am
Engine: 5.0 carbed
Axle/Gears: 9 bolt
I cant find it, and the motor is on a stand? I'm feeling pretty stupid right now! I dont see a "8" "F" or an "E"??? The vin is "E" which i know is the 305TBI, i just want to know if the motor that came out of it is a 350TBI or a 305TBI. Thanks
Old Oct 8, 2011 | 08:23 AM
weesel72's Avatar
Car: 85 trans am
Engine: 5.0 carbed
Axle/Gears: 9 bolt
Are you talking about where the water pump bolts to the block?
Old Oct 8, 2011 | 10:27 AM
92Firebug's Avatar
Car: 1992 Pontiac Firebird Base
Engine: 305 TBI
Transmission: 700r4, B&M shifter & shift kit inst
Axle/Gears: 3:23....10 bolt
those numbers and letters are in your vin which is bottom right side of ur windshield
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
if you have the engine out, then look on the pad behind the driver side head, on the flange the trans bolts too. there with be a number there and possibly even a GM5.0L.
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
