Help bad leak!!!
Old Apr 16, 2011 | 08:17 PM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
Help bad leak!!!
today i found a load of water in the back of my car it seams to be coming from the seal between the glass and the deck lid how do i fix this and what do i use to reseal it?
Old Apr 17, 2011 | 01:30 AM
racerx520's Avatar
Re: Help bad leak!!!
new weather strip? the weatherstrip doesnt need to do much towards preventing water from entering under the rear glass on these cars though. maybe a rust condition hidden somewhere? had a load of rust hidden on the top of the wheel well on the rears, found it cuz one day my stuff in the back was always wet and the window was constantly fogged when it rained. turned out the water was being thrown from the tires up into the car through the large rust hole. its since been repaired
Old Apr 17, 2011 | 06:35 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
i have had this same problem it is coming from the A-pillar on either the driver's or passenger side
Old Apr 17, 2011 | 06:53 AM
Red 87 GTA's Avatar
no i mean water literally poors out of the little trim piece on the deck lid when you open the gate
Old Apr 17, 2011 | 07:03 AM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
I just replaced the back glass on my camaro. Not complicated but not a lot of fun either. You're going to need an extra set of hands and some fine wire in addition to your screwdriver, sockets and windshield butyl(stuff that they use to install windshields). You can leave the hatch on or take it off, your choice. Take all of the trim pieces off of the underside of the hatch. There are 4 bolts that hold the spoiler to the glass. If you leave the hatch on, loosed but don't remove yet. Use a putty knife to push through the existing seal to get a hole started. Thread the wire through and use it to saw the spoiler off of the glass. Guitar string works really well. Oh, yeah, remove the 4 screws holding the side molding to the spoiler. You will need to remove the hatch supports and prop it up. This is why I recommend removing the hatch. It gets difficult supporting it while you work. Anyway, once you have it apart, clean the old seal off. Mineral spirits dissolves it pretty well. Napa carries the butyl or you can get it online. Get the primerless if you can find it. Just a word of warning, this stuff is very sticky and it can only be removed with mineral spirits. You will get it on you. If your hatch spoiler doesn't line up, this is a good time to fix that. Before you take anything apart, measure how much you need to move the spoiler and mark it with tape. We you re-assemble, line it up to your marks. Put a pretty thick bead of butyl on the spoiler and re-assemble. Let it cure for a couple of days before you expose it to weather.
This sounded a little eratic, but I've only done it once and my memory isn't the greatest. Let me know if you have any questions or need clarification.
Steve
Old Apr 17, 2011 | 07:41 AM
KITT1983's Avatar
can you please post a photo of the area that you are talking about and is your car a ttop?
Old Apr 17, 2011 | 10:56 PM
racerx520's Avatar
best suggestion i can give without seeing this happening is to remove as much trim as you can and investigate. possibility that the gasket on the spoiler is no good and water is coming in through the holes for the bolts. again i dont know because im not sure what trim piece youre talking about, im assuming its on the underside of the deck lid and that is really the only thing i can think of
Old Apr 18, 2011 | 07:37 PM
Red 87 GTA's Avatar
i fixed it the seal between the decklid and glass was almost gone and the water was just pooring down the glass into the car.
Old Apr 18, 2011 | 08:27 PM
KITT1983's Avatar
thats good to hear
xxx3man`
Sep 23, 2015 10:37 PM
greenyone
Sep 2, 2015 03:39 PM
RyanJB
Sep 2, 2015 01:27 PM
mike_c
Aug 27, 2015 04:32 PM
