Camaro Underbody Plastics
Old May 26, 2011 | 02:09 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
After 20+ years, I wonder how many of the OE pieces are still in place? The first pic is the DEFLECTOR, Air Lwr. The second pic is BAFFLE, Rad Air (Lwr). The third pic is BAFFLE, Air Lwr Otr--LH, which serves to somewhat protect the Orb of Power (vacuum tank).
JamesC
Attached Thumbnails Camaro Underbody Plastics-img_0201.jpg   Camaro Underbody Plastics-img_0202.jpg   Camaro Underbody Plastics-img_0203.jpg
Old May 26, 2011 | 02:13 PM
JamesC's Avatar
Re: Camaro Underbody Plastics
The fourth pic is BAFFLE, Air Lwr Otr--RH. The last pic are RH and LH off car (the two small holes in the LH are not OE, BTW).
JamesC
Attached Thumbnails Camaro Underbody Plastics-img_0204.jpg   Camaro Underbody Plastics-img_0205.jpg
Old May 26, 2011 | 02:23 PM
Drew's Avatar
Re: Camaro Under Body Plastics
The 4th pic just died.
My Iroc was missing just about everything under the front bumper cover. I've got most of it back together now. I still need to find the covers left & right.
Old May 26, 2011 | 02:55 PM
JamesC's Avatar
Since the above plastics have to do with 'air,' note the following, especially #66 and #77. While the file is for 89-90 models, my 85 IROC is equipped with them.
JamesC
File Type: pdf
File Type: pdf
File Type: pdf
Old May 26, 2011 | 05:25 PM
Dartht33bagger's Avatar
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
My car has all of them still, except the one on the drivers side is bent because the PO got hit in the drivers side fender and it bent the plastic.
Old May 26, 2011 | 05:56 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
as do i , please let me know if you find a source . thanks , good luck .
Old May 26, 2011 | 06:11 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Drew you need left and right?
http://i283.photobucket.com/albums/k...20sale/231.jpg
Old May 27, 2011 | 07:56 AM
puma1552's Avatar
Curious, part #63, what the radiator baffle shown in your second pic, I notice the "teeth" on the front edge are tucked in above the inside of the chin spoiler.
On my '90, the teeth are attached to the underside of the chin spoiler--you can actually see a tiny peek of it when looking for it at the front of the car. It appears factory, anyone else's like mine or are they all like James's?
Old May 27, 2011 | 11:39 AM
JamesC's Avatar
It would 'appear' that the baffle is designed to be placed above/inside the spoiler. I'll be interested to see what other members say.
JamesC
Old May 29, 2011 | 12:06 PM
JamesC's Avatar
I looked at an 88 earlier today. While the baffle was missing, from wear marks, I'd say the baffle went above.
JamesC
Old May 29, 2011 | 12:11 PM
puma1552's Avatar
Interesting, thanks for checking that out. I'll have to get under mine and get a better look at things.
Old Jun 9, 2011 | 04:03 PM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
Just had a look underneath my car.
The baffle goes over the chin spoiler covering the connecting teeth.
Maybe after repainting it got re-assembled the wrong way around. You said your car was repainted once.
Old Jun 10, 2011 | 12:07 AM
puma1552's Avatar
That's a good possibility, looks like I'll have to crawl under there and reverse it when I get back home later this year. Thanks for the heads up.
Old Jun 14, 2011 | 06:47 AM
stealthroc89's Avatar
Car: 1989 IROC-Z
Engine: 355, 6.0 (LQ4) soon
Axle/Gears: Borg Warner 2.77 for now
The baffle goes above 100% sure. I need to figure out how to put one on a spoiler that never had one, or just get on with the mounting hardware. Does anyone have or can get a good pic of one? Maybe I can make some. Also, what is it for? Is it there to keep the spoiler stiff for high speed aerodynamics?
Old Jun 14, 2011 | 07:02 AM
Engine: LO3
Originally Posted by stealthroc89
The baffel goes above 100% sure. I need to figure out how to put one on a spoiler that never had one, or just get on with the mounting hardware. Does anyone have or can get a good pic of one? Maybe I can make some. Also, what is it for? Is it there to keep the spoiler stiff for high speed aerodynamics?
From the shape and location I think it's as much support as preventing the front GFX from scraping/folding when scraping.
Old Jun 14, 2011 | 07:12 AM
JamesC's Avatar
Note that the piece is called a BAFFLE, Rad Air (Lwr), and not brace. What's that mean? Dunno. I wonder, however, if the baffle and deflector/air damn don't work in conjunction to direct air upward, which their design/shape would seem to indicate.
JamesC
Old Jun 14, 2011 | 07:46 AM
Engine: LO3
I don't mean to be disrespectful, but if that really was the intended purpose of the piece it's the worst designed aero piece I've seen in a long time.
I accept if someone at GM hoped it would help, but I can not expect an engineer to expect it to work in assisting the airdam.
The way I understand the deign, and please mind, it's only my personal interpretation and I would accept any good argument in proving me wrong, is as following:
The airdam/deflector is an aero piece whose purpose it is to create a high pressure area in front of itself and a low pressure area behind itself. This helps air searching an easier way of getting past the airdam, which ideally is through the radiator.
To provide the lowest possible hindrance the ideal shape and position for the baffle would be if it were non-existant. It would not hinder airflow in front of the aidam/deflector that way, and would provide optimal flow towards the radiator.
GM put the thing there for a reason however. Possibly the intention would have been to direct the air that runs over the baffle towards the radiator in an angle that would not have a negative effect on the workings of the airdam/deflector.
As you can see in the image below (that airdam is taller and wider then stock) all the baffle really does for the airdam is that it effectively prevents air from moving in the area behind the front GFX, limiting the amount of air the airdam can effectively "deflect" towards the radiator.
It might be just me, but I kind of fail to see how it assists the airdam.
Apologies for diverting this far from the original topic.
Old Jun 14, 2011 | 07:56 AM
Car: 1989 IROC-Z
I guess they killed 2 birds with 1 stone on this part, limits high speed deflection of the spoiler and cuts out some of the turbulence made in the void behind the bumper. I also thought it helps direct air to the filters, but it looks like the spoiler directs air over it
Old Jun 14, 2011 | 08:47 AM
JamesC's Avatar
Actually the whole under car plastics question is interesting. From the dictionary, for what the definition is worth:
Baffle: (Engineering / Mechanical Engineering) to check, restrain, or regulate (the flow of a fluid or the emission of sound or light).
Or air?
JamesC
Old Jun 14, 2011 | 08:59 AM
puma1552's Avatar
Air is a fluid in engineering.
My guess--without thinking much about it--is that with the center baffle, they are trying to control the type of flow, be it turbulent flow or laminar flow (most likely the latter), as determined by what's known as a Reynold's Number:
http://en.wikipedia.org/wiki/Reynolds_number
Again, just speculating based off of fluid dynamics from when I was working on my chemical engineering degree.
As the air hits the air dam, the air is surely exhibiting turbulent flow which is unstable, but by having that baffle in front of the air dam, it helps stabilize the upward airflow, smoothing it out by channeling it.
Old Jun 14, 2011 | 09:40 AM
Engine: LO3
Ok, that appears to make sense.
Only had the basics of fluid dynamics covered during my education, and I somehow never completely had all the interestings tuff covered.
I assume the purpose of the part will then lean towards changing from an open channel state to a wide duct like kind of controlled state, which does make sense.
Having thought about it a bit, I can see how the air going to the air dam will be channeled through cleaner compared to having an empty space behind the front GFX piece.
Old Jun 14, 2011 | 02:51 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
My 89 iroc has the baffle and I see how it works but I need one for my 92 Z convertible which is running hot and one for my 92 purple haze Z which I am starting on. The baffle seems to work similar to roof line and rear deck of a nascar stock car. Air goes over the roof and follows the rear glass over the spoiler providing down force. I saw a special on them once. An indy car has three thousand pounds of downforce and at speed could run upside down. A Nascar has three hundred pounds of down force. If anyone knows where to get a baffle please advise.
Old Jun 14, 2011 | 03:19 PM
JamesC's Avatar
http://www.rickscamaros.com/camaro-r...1987-1992.html
JamesC
Old Jun 17, 2011 | 09:18 AM
JamesC's Avatar
Hey, Uncle,
The following site apparently has both the LH and RH pieces (14079874 and 14079873).
http://parts.nalleygmc.com/products/.../14079874.html
JamesC
Old Aug 1, 2011 | 02:04 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
I was searching through threads, looking for info on air dams. Came across this one.
Ok my car runs a hot, i recently flushed the Rad, and changed the cap. I have a thermostat to put in. But my big question is, does it really make a big difference to have a air dam? My car does not have one. I read the pro's and cons in this post, but still not sure what your saying. So could you explane in layman's terms. Thank you
Old Aug 1, 2011 | 02:15 AM
Engine: LO3
Yes.
My car overheated without, but stays cool with airdam.
In laymans terms, without airdam most of the radiator surface will be unused.
The air entering through the grille insert only really covers like 20% of the radiator surface, and is very erratic in it's direction.
The airdam prevents the air entering underneath the car from moving through unhindered. It's an obstacle. In front of this obstacle you'll get a high pressure area, behind it a low pressure area. The air wants to get into the low pressure area and will use the path of the lowest resistance. Part of that air goes through the radiator to fill up that low pressure area, effectively using more of the radiators surface.
Old Aug 2, 2011 | 12:54 AM
Engine: MPFI
Thank you Solitaire For great info. Does anyone know a place to buy? Or does anyone have a extra laying around they would like to sell? Thanks
Old Aug 2, 2011 | 01:18 AM
Engine: LO3
Hawks has them for about $50.
For about $10-15 and about 30 minutes work you can DIY one.
Old Aug 3, 2011 | 08:52 PM
Engine: MPFI
Solitarie maybe you could make one for me and I pay you for it. I have gone to dealer, ricks, third gen ranch, and a few other part places, with no luck. I flushed Rad over last weekend. Drove it today and it over heated to the point of leaking on the ground. Oh wow just looked, you are from Germany. Ok is there any one else who makes one that works? Thanks
Old Aug 3, 2011 | 11:55 PM
Engine: LO3
Originally Posted by camarosrock1989
...Oh wow just looked, you are from Germany. Ok is there any one else who makes one that works? Thanks
Yep. that´s the only problem. Shipping.
I can give you some detailed instructions (maybe over PM to not clutter this thread with fabrication details), and I made my current airdam with only a handsaw, scissors, a few nuts and bolts and the materials required. Oh, and a drill. No special tools required.
Why not pick up this one? Shipping is the only thing preventing me from ordering the original.
http://www.hawksthirdgenparts.com/airdams.aspx
Old Nov 18, 2011 | 02:47 PM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
EUREKA! Bump on this thread because i have been looking for what this part is for about a year now and nobody knew what i was talking about, lol.
Numbers 63-65 i believe in the first PDF file are exactly what i was looking for.
Only problem is after Googling for hours, the only vendors that have them they are discontinued.
I still have the side pieces to the "duct", just don't have the pieces that attach to the chin(63), and the piece that attaches to that(the "duct") as well as the piece to cover the hole where the hood latch is.
If anyone has come across these parts, or has successfully made their own, please i would love to know where, or how.
Thanks in advance for any help
The main reason is the fact that on the highway, when i got behind a truck with shiny doors, I noticed that the chin spoiler was flapping rather severely, which i realized is why the car shakes anywhere over 50mph.
Old Nov 18, 2011 | 11:24 PM
Engine: MPFI
Nice looking camaro you got there will. Looks a lot like mine..haha
What rims do you have on it? Thanks
Old Nov 19, 2011 | 07:36 PM
willexoIX's Avatar
Ironically we have the same car. Even more ironically I am in the process of doing the exact same paint job you already have. Before I wasn't sure how it was gonna look, but now I am excited as hell to get done with it cause it looks awesome!
Only thing i'm doing different is I may go a semi-gloss on the black, and doing the ground effects black with it. Front bumper will probably stay red, so i can tie the black to just the headlight buckets. Then the rims are getting powdercoated black.
Then polish it off with a 1 inch drop, hide the antenna, blackout the brake lights and its done. Nice and simple; wish it that simple to finish, lol
Wow, way off topic, but I cant help talking about my Camaro, lol.
shoot me a pm camarosrock
Old Feb 3, 2012 | 11:26 PM
willexoIX's Avatar
Oh, I forgot to tell you what rims, proline alloy, pepboys had them but discontinued them. I got them as a trade on the stock 15 in camaro rims
Old Apr 8, 2012 | 04:39 PM
Engine: MPFI
JamesC
Hey James i was wondering what size screws are for the 2nd pic baffle?
I put the airdam on, and i have tha baffle. Has like metal clips attacked.
Just not sure how to install it. I'm thinking it goes on inside of front lower
ground effect. close up pics would be awesome!! Thanks for sharing the info.
That is what prompted me to get the airdam and baffle. I had the rest on the car. Great thread
Old Apr 9, 2012 | 02:58 PM
JamesC's Avatar
ground effect.
I checked various sources but failed to find the size. You might try this as I've found it very useful over the years: Hit the bone yards, not only for the parts you may need, but also to see those parts are assembled. I'm not sure that my close-up is any better than pic 2. Hopefully, the pic is clear enough to show that the metal piece goes inside the front ground effect. I seem to recall that the metal piece is actually attached to the ground effect and that the screw secures the baffle to the metal piece.
JamesC
Old Apr 9, 2012 | 04:05 PM
Twiztid Tim's Avatar
Car: i have a 1991 camaro rs
Engine: 5.0
Axle/Gears: stock
will an 85 front end bolt onto a 91 i like that front cap better and i want to remove the ground effects to make it look more muscular? just currious?
Old Jun 20, 2012 | 06:47 PM
bucanero's Avatar
Car: 92 Camaro RS, 25th Anniversary
Engine: 305 cid, 5.0L V8, TBI
Transmission: 700R4, 4 Spd Automatic Transmission
My 92 RS only have the the driver's side baffle and the air deflector, but only two out of six requred screw are attaching on the passenger side. I bought six new bolts with the exact same size. The remaining 4 holes are too big to fit them so if anyone knows the right clip or brkets needed to attach the air dam into the lower radiator support and where to buy them I would appreciate it.
Old Feb 17, 2013 | 10:51 AM
92camaro25th's Avatar
Car: 1992 z28
Engine: 5.0
Axle/Gears: 2.73 posi
I've been searching all around but can't seem to find the baffle piece for my 1992 camaro z28 if anyone knows were I might be able to find this it would be greatly appreciated.
Old May 12, 2013 | 07:52 AM
slowboy's Avatar
Car: 1990 CAMARO RS
Engine: 350 - replaced 305 with 350
Transmission: 5 SPEED
Axle/Gears: STOCK [?]
would like to know materials and dimensions to DIY one...
Old May 12, 2013 | 09:15 AM
slowboy's Avatar
Car: 1990 CAMARO RS
ok...after searching online, and different forums for help and advice, I've now came to the point of being tired of looking, and made an uneducated decision to go for it...here's what I'm going to use...per diagram - #65, 69, 70, 78, 79, 83, and 2 piece air dam...my wife's car has been on stands for several months while I fixed damage from wreck, and she's getting impatient wanting to drive it...if it doesn't overheat, GREAT...if it does, I'll just go back to searching...
Attached Thumbnails Camaro Underbody Plastics-camaro-parts.jpg   Camaro Underbody Plastics-pix-006-small-.jpg
Old Sep 22, 2013 | 09:13 PM
  #42
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Where would i find a baffle in Pic 2. I've looked in local So. Cal junk yards but 4rd gen Camaros are quite rare in junk yards and the ones you do find are picked to death.
Old Sep 25, 2013 | 04:15 AM
  #43
slowboy's Avatar
Car: 1990 CAMARO RS
try hawksthirdgenparts.com
Old Sep 25, 2013 | 11:18 PM
  #44
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
here:
http://www.hawksthirdgenparts.com/pr...r-Air-Dam.html
Old Aug 31, 2015 | 01:14 AM
  #45
crzycamaro86's Avatar
does anyone have pics of all the air dams on a 91 rs
Old Aug 11, 2016 | 09:20 PM
  #46
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Yeah, please of your car has all air dams, please post pics
Old Aug 12, 2016 | 07:12 AM
  #47
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
I think James' pictures in the OP pretty much sum it up. The only thing not shown is part 69 and the few parts around it which goes in between the radiator and the front grill. The flat air dam posted in the link to Hawks is the one that pulls the air back up to the radiator to keep it from overheating. All I'm running right now is that and the baffle between that and the front bumper.
Jeremys87
Jul 14, 2022 09:08 PM
Caspar
Jun 19, 2016 11:19 PM
MORREALE5
Sep 13, 2015 09:16 PM
mustangman65_79
Aug 13, 2015 07:36 AM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
