installing hood pins
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
I recently purchased a fiberglass, liftoff hood. once i get the hood pins installed, im wondering what is an accuate way of marking places to drill for the hood pins (in the hood)?
there isnt much room for error with this, seeing as i would like the hood to fit properly and actually look decent.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: installing hood pins
If it were me, I think I'd sacrifice a roll of the wife's lipstick. I'd install hood and get it aligned without the pins in place. Then I'd paste a glob of lipstick on top of the installed pins, then close hood slowly, making sure it's aligned properly, until the hood touches the lipstick and makes a round mark on the underside - and drill there.
(You know my wife loves when I come in and ask for lipstick
) Supreme Member
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
One good thing is the round cover they have to go around the hole can hide a little fudge room as needed. only done it 3 times in my life [ 2 hoods, 1 notchback] and the best lay out, measure 50 times in many direction, those covers saved me for a bit of fudge room.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
With a "lift off" hood. Sounds like at least a two man job. Would he drill the front pins first then use those to set the back pins ?I'm thinking the first photo may be a bit over kill for a DD so I was thinking the second one could be it.Is that the end result your looking for ?
What I did with mine is use blue locktite. I put a few drops on the top of the pin and gently lowered the hood. I then used one of the christmas tree drill bits to make the first hole from the bottom to the top. After I had that one I then began drilling that hole from the top down until I had the size I needed. The reason I did top down is that it makes a little rough edge that I didn't want on the top. Go slow and keep on fitting.
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
