Candy apple red Engine paint?
Old Jun 15, 2011 | 02:22 PM
nitrous87's Avatar
Car: 87camaro 357ci
Engine: xe294,scat crank,6" rods,Dartheads
Transmission: th-350 3000 stall
Axle/Gears: 4th gen rear 4.10 gears
I decided to paint my engine and transmission candy apple red so I went and spent $250 on all the stuff. Here is what I got
PPG Epoxy primer
Nason Spectramaster Red bascoat
X-treme Klearkote
And House Of Color Apple Red candy concentrate
My friend told me that it wasn't a good Idea to lay down a red base coat because it would be harder to tell it was candied. He said it would be better to lay down a silver or gold base coat and candy apple red over that. The only thing I am worried about is the engine turning out more silver than red. I really want my engine red but also want a distinct candy look. Any suggestions?
Old Jun 15, 2011 | 03:15 PM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Re: Candy apple red Engine paint?
Your friend is correct to a certain extent. Urethane Candies (or Kandy in HOK's parlance) are a multi-layer process used to bring the color up slowly. Because of this, the base coat is very important and VERY important to your final color. Red over silver or gold using conventional Kandys might be a 15 coat endeavor, depending on the final color you're looking for. You've purchased a "Kandy Koncentrate" and it should be used in an intercoat or topcoat clear to get the same effect as the original urethane kandys. You can put the red Kandy over the red base, nothing wrong with that, but you'd better do a test panel and count the coats before you spray your drivetrain and most importantly, make sure you can achieve the color your looking for.
jaridjohn
Jul 8, 2024 03:49 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
87350gtanj
Aug 8, 2015 10:32 AM
