Hood Binds
Old Jun 22, 2011 | 06:58 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Hood Binds
When I lift my hood about 8 inches it binds in the rear. I have to lift one side then the other to get it up. Any thoughts on what's going on??
Old Jun 22, 2011 | 07:20 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Hood Binds
Struts or needs to be re-adjusted
Old Jun 22, 2011 | 07:37 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Re: Hood Binds
I have binding on both of mine. It helped to spray white grease on the hinge joints. I assumed it was a design flaw. I would like to know how to re adjust.
Old Jun 22, 2011 | 08:33 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Re: Hood Binds
My struts good. It is like if I try to lift it I would creas the hood about a foot away from the cowl:
Old Jun 22, 2011 | 09:31 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Transmission: auto & t5
Re: Hood Binds
i have two camaros and one bird here and they all do the same thing.
Old Jun 22, 2011 | 11:52 PM
memphis1967's Avatar
Car: '84 Z28
Axle/Gears: 98 T/A 10 bolt. Auburn, 3.42
Re: Hood Binds
i have brand new struts on a fiberglass hood, same issue
Old Jun 23, 2011 | 12:27 AM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
Re: Hood Binds
Have the same. I guess it´s caused by the dimensions of the lifting mechanism in combination with production tolerances.
Some people will suffer from this, others not, adjusting might help and grease definately will.
When lifting the hood the rear edge of the hood moves in a slight arc, first away from the windshield and then up. To achieve this a multi link mechanism was used that creates a virtual pivot point.
To fit this all under the hood, the dimensions were kept to a minimum and materials used are cheap. That causes fricture on the pivots, and if the torque applied to the pivots does not exceed the fricture your hood binds.
Again, manufacturing tolerances cause this to happen on one of two sides, or both, or none.
I will fit a different hood sometime soon and will have a look at what good adjusting will do.
As said, a set of good gas shocks and some grease will help a lot.
Old Jun 23, 2011 | 12:43 AM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Re: Hood Binds
Well. In a way I feel better that I am not the only one. LOL. What about hinges? Would new ones help??
Old Jun 23, 2011 | 01:17 AM
Engine: LO3
Re: Hood Binds
You could try the ones you have. Most likely they´re still working fine.
Old Jun 23, 2011 | 07:35 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Hood Binds
if struts are good as you say they are . a good cleaning & re-lube of ALL pivot points on hinges . try carb. cleaner spray with plenty of rags to prevent over spray . then re-lube with white litheum spray grease . good time to do the same with hood latch . you WILL be suprised at how much better they work . good luck .
Old Jun 23, 2011 | 08:39 AM
Re: Hood Binds
I would still like to know how to adjust the mechanism.
Old Jun 23, 2011 | 09:44 AM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Re: Hood Binds
That happens to me in junk yards all the time, I jus tpull toward me while pushing up. Once it passes a certain point, it just goes up.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
