5.7 TPI Emblem
Old Jul 5, 2011 | 04:48 PM
87rattler's Avatar
Car: 87 Iroc-Z28
5.7 TPI Emblem
Just received mine today, Anyone give me the exact location of the emblem on the rear bumper (with Photo). Two way tape or glue? Thank you so much.
Old Jul 6, 2011 | 08:02 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
Re: 5.7 TPI Emblem
I believe they make specific adhesive for items like emblems. This is available at Autozone although it might not be the correct one.
http://www.autozone.com/autozone/acc...er=316901_0_0_
I removed my old TPI emblem since it was falling off. Looks like factory used a black colored adhesive that dried to a rubberized texture. My helms manual for 92 camaro says to install 5.7 TPI emblem 3" (76mm) from the left side of indentation on bumper. I know 91-92 bumpers are slightly different from 87' however GM might have kept spacing similar.
Note for anyone using non 5.7 TPI emblem ("Tuned Port Injection" only), spacing is 3.8" (96mm) from left.
Old Jul 7, 2011 | 04:33 AM
87rattler's Avatar
Car: 87 Iroc-Z28
Re: 5.7 TPI Emblem
thanks, i looked on the thread of "rear photos of cars" and sort of determined where it should go. It looks much better now with it on. It actually came with 2 way on it so I'll keep an eye on it. One member said, in another thread, that it differed on each car, out of the factory.
Old Apr 3, 2012 | 11:28 AM
xcalibur's Avatar
Car: '95 Impala SS
Engine: 350/LT1
Transmission: (Sold my '89 Formula 350)
Re: 5.7 TPI Emblem
The correct adhesive is: "3M Emblem Cement", available @ many parts stores. You will not be disappointed, it will out-perform any thing else you might use.
Old Apr 3, 2012 | 11:55 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Re: 5.7 TPI Emblem
How do you tell the difference? I have an emblem I'm not going to put on my car, I might sell it instead, but it says 3M on the back.
Old Apr 3, 2012 | 01:44 PM
xcalibur's Avatar
Car: '95 Impala SS
Engine: 350/LT1
Re: 5.7 TPI Emblem
I'm talking about the 3M Emblem Cement found in a white toothpaste-style tube w/red lettering on it. It's probably bigger than a 4 oz tube, and somewhat pricey, about $12 a tube, if memory serves. But you'll find many uses for it after you get it. Sounds like your emblem may have come w/3M double backed tape, instead.
diana227vegas
Jul 8, 2016 12:27 AM
stalkier
Dec 6, 2015 11:25 PM
777Shock777
Oct 29, 2015 04:30 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
