best upper door bushings?..who?
Old Aug 6, 2011 | 12:38 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
hi, i need to replace my upper door bushings ,,the doors sag a bit,,i would like to change both ,,any apecific types out there i should look for?..saw some on ebay...
Old Aug 6, 2011 | 12:54 PM
LarryL's Avatar
Car: 84 TA,69 camaro,81 vet 92 vet
Engine: 400
Axle/Gears: 3:73
Re: best upper door bushings?..who?
I got a set of ebay. Just jackup door to make it level. Take old ones out, clean, install new ones. The bushing fits in a little way and self contained screw pull its all the way in. 2 bushings each pin. You don't have to remove door. First one took me 3 hours, others 45 min. I did upper and lower on both doors. The doors will be very tight for about 2 months, then fine.
Old Aug 6, 2011 | 12:58 PM
mooch1's Avatar
Transmission: T5 WC
you didn't remove the doors?...can you point out the ones you got on ebay?
Old Aug 6, 2011 | 01:11 PM
LarryL's Avatar
Engine: 400
Axle/Gears: 3:73
I just looked the guy I bought them from has none listed. I paid $40 for the 2 doors.
They are just like these
http://www.top-downsolutions.com/bod...rior-c-21.html
I put grease fittings on mine.
Old Aug 6, 2011 | 01:14 PM
mooch1's Avatar
Transmission: T5 WC
you got a good price..they go for double that one door!...can you explain a little how you replaced the top ones without removing the door?...the bottom ones seem easier..thanks for your help.
Old Aug 6, 2011 | 01:28 PM
LarryL's Avatar
Engine: 400
Axle/Gears: 3:73
Open door, place a jack under door (put a piece of wood between door(not on door skin) and jack). Jack door up, this keeps it in place. Use a dremel to grind down top of pin. Drive the pin out. Insert new bushing. Just make sure you get all the head cut away. You will be able to see the pin shaft where it goes through the hinge.
Old Aug 6, 2011 | 02:07 PM
LarryL's Avatar
Engine: 400
Axle/Gears: 3:73
I forgot, I also redid the dented spring pin while everything was apart. You need a special tool to reinstall the spring.
Old Aug 6, 2011 | 03:52 PM
mooch1's Avatar
Transmission: T5 WC
ok,,good to know about the spring...this method is for the upper part?
Old Aug 6, 2011 | 04:03 PM
LarryL's Avatar
Engine: 400
Axle/Gears: 3:73
Yes, I did the top first.
Hotrodboba400
Dec 10, 2019 07:07 PM
camaro1185
Oct 26, 2015 06:51 AM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
