Fixing strut tower rust (with pics)
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Took 2 full days of non-stop grinding/beating/welding but it's finally rust-free in the wheel well. First a built a jig out of 22ga sheet metal and 3/16th round bar. This allowed me to cut in the same locations on the car and donor piece. Even then it was hours and hours of cutting and trial fitting until it was just right. Then I welded from both sides, ground the engine side down, and primed. Paint will come tomorrow, I just couldn't take any more after 13 hours of work today I just had to quit for the night.
This was no small project. Even though it doesn't make the car look and better, go any faster, or look any nicer it still had to be done at some point. The passenger side will be done tomorrow, but there's only a small patch of rust that won't take long to fix. After that I have Founders performance camber/caster plates on their way that'll go on before I have an alignment done.
Here's where things started:
Here's the jig:
Here's what was removed:
Here's some welding:
Here's the jig:
Car: '91 LS6/T56/9"
Engine: LS6
Re: Fixing strut tower rust (with pics)
Here's before primer:
Here's in primer:
Here's in primer:
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Even though no one will probably ever know what was done, you get to keep the satisfaction of knowing it was done by you the right way. Well done.
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
Car: '91 LS6/T56/9"
Engine: LS6
The floor is next. There's one spot (the most common) by the drivers feet that is a mess. I found a guy here that's shopping up a good floor for me so I'll be on that as soon as I get the metal. I really didn't want to use sheet metal because I think it'll look cheap.
BTW, I still have the passenger side tower from third gen ranch if anyone needs it. I bought both sides, but my passenger side isn't bad at all.
Car: 86 Trans Am
Engine: 350 Roch-4bbl
Axle/Gears: Normal
Hey Buddy, I am lookin for the same thing for both sides, more drivers.
What was the search item number for this part?
Engine: 4++,350 & 305 CIs
Outstanding work!
Car: 1992 Camaro RS
Engine: 3.1 V6 (Soon to be 305)
I got at same problem.. But how did you go about getting the one off the donor car?
Car: '91 LS6/T56/9"
Engine: LS6
Thirdgenranch has them. It's where I got mine.
Car: 88 GTA Notch/01'WS-6 VERT
Engine: 5.0 LB-9/5.7 LS-1
Transmission: 700R-4/4L60
Axle/Gears: borg warner 3.27's
Nice work I sold an 88 gta a few months back with a rot hole in the drivers strut tower u could stick both fists threw!!!
