Trying to restore - Rear window hatch outter trim peaces...
Old Aug 11, 2011 | 02:20 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I removed the rear window trim and burnt out all the sealant. I have been contemplating on powdered coat but its nearly imposable to get all the sealant out with out acid dipping these... I keep telling my self its just a trim peace, Im not to worried about it i think just going to disc it down and use metal etching primmer.... Now what should i do for a top coat? looking for some rattle can that can survive the sun and other potential weather conditions... I think the factory just used a lacquer based paint i plan on some type of enamel based spray paint... kinda want it semi gloss so nothing to glossy... Ideas??! Needs to be durable!!
Old Aug 11, 2011 | 03:01 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
Re: Trying to restore - Rear window hatch outter trim peaces...
I saw an episode on horsepowertv a while back and they used I believe Duplicolor trim black paint......
Old Aug 11, 2011 | 04:20 PM
jminton's Avatar
Car: 1985 IROC
Engine: 305 4bbl H.O.
Transmission: WC T-5
The problem I had with using a disk was that the metal in mine has a gulley. You are correct that it is lacquer based from the factory. I am considering stripping the old paint and putting naval jelly on the rust spots to clean them up. I think this will be better because the disk may cause the metal to warp due to heat. That duplicolor trim paint seems to be the way to go, but I wonder how UV resistant it is.
Old Aug 11, 2011 | 05:43 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Call your powdercoater- he may be able to give you some pointers. I was planning on removing mine, having them media blasted if that won't warp them and going with a powdercoat.
Ask him a) if he can get that gunk out with media blasting- baking soda or charcoal maybe- b) if he can powdercoat the OUTSIDE ONLY(a buildup of powdercoat on the inside may make them impossible to reinstall) and c) if he can do all this WITHOUT WARPING THEM.
Old Aug 11, 2011 | 08:23 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
https://www.thirdgen.org/forums/auto...tal-hatch.html
Old Aug 22, 2011 | 01:15 PM
FueledSoul's Avatar
How about the adhesive? Just window adhesive? when i took it off it didn't seem the like stuff that's used on the windshields...
Old Aug 25, 2011 | 10:18 PM
FueledSoul's Avatar
bump
Old Aug 27, 2011 | 12:18 PM
FueledSoul's Avatar
bump
Old Sep 11, 2011 | 11:05 AM
FueledSoul's Avatar
bump
Old Sep 11, 2011 | 11:33 AM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
I thought someone said that the early years had adhesive applied all the way around, and in the later years only had it applied to the ends?
Old Sep 11, 2011 | 02:52 PM
FueledSoul's Avatar
all of the ones IV seen have it all around it
Old Sep 12, 2011 | 07:16 PM
Car: 91 z28
Transmission: 4L60e
Remove molding
-Use an acetylene torch with a number two tip and start from top of left or right moldings and apply heat for a distance of 200mm (8") in a back and forth motion.
-Immediately grasp heated section with pliers and pull away from glass.
-repeat for remaining moldings
Old Sep 12, 2011 | 07:21 PM
Car: 91 z28
Transmission: 4L60e
Install
-Apply clear urethane primer to glass
-Apply black urethane primer over same areas of glass. Allow primer to air dry for five minutes.
-Apply black urethane primer to inside molding channels. Allow primer to air dry for five minutes.
Old Sep 12, 2011 | 07:38 PM
Car: 91 z28
Transmission: 4L60e
-Apply a 4.5 mm (3/16") bead of urethane to inside molding channels. Do not apply urethane for a distance of 25mm (1") from top ends of moldings.
-Escutcheon into top channel of right molding
-install left, right.
-Adjust holes in molding tabs to align with holes in glass
-Tap left, right molding with mallet to seat them on glass.
Inspect
-Inspect along radius to see that they are properly seated to the glass
-Apply tape over moldings every 200mm (8") to hold in place during curing. Allow 6 hours cure time.
Old Sep 21, 2011 | 01:04 PM
FueledSoul's Avatar
Thanks! So i used a green disc to take all painted surfaces down to bare metal then just cleaned them up with some wax and grease remover, then sprayed a few light coats of self etching primer, then used the trim paint... im completely amazed at how great the trim peace look now. The paint was easy to lay down and smoothed it self out before drying it looks 10+ better then factory im pretty impressed... now will see how durable it is...
Old Apr 4, 2012 | 09:32 PM
Car: 91 z28
Transmission: 4L60e
Update? I am at this point now in my build. Is paint holding up?
Old Apr 4, 2012 | 10:13 PM
FueledSoul's Avatar
Its on the hatch glass now... i wish i would have did a light sand after i used the green disc to take all painted surfaces down to bare metal... some areas pulled up when i had tap going around the trim... most likely because it needed that extra bite from a some gritty sand paper ...
Old Apr 7, 2012 | 05:21 PM
Ticeblue's Avatar
Car: 91 RS
Engine: 305 TBI
Transmission: 700R4 shift kit vette servo
Axle/Gears: 3.73 Eaton Posi
How does the paint look otherwise???
Old Apr 7, 2012 | 05:25 PM
FueledSoul's Avatar
Looks ridiculously amazing! I'll snap some pics and post them sometime
Old Apr 7, 2012 | 05:41 PM
Ticeblue's Avatar
Car: 91 RS
Engine: 305 TBI
Sweet dude I'm thinking about doing it....could the sanding be done by hand I'm afraid to use my 4 1/2 in grinder on them
Old Apr 7, 2012 | 05:53 PM
FueledSoul's Avatar
Yes, but do you really want to spend 12 hours hand sanding? You can get the green style scotch bright discs for your 4 1/2 grinder... That's what i used... just single speed 4 1/2 grinder with a green disc... It will only take the paint off, it wont grind or take down the metal... took me about 10mins to do each trim peace ( left & right ) some areas you might have to get with sand paper but very very few! the green style disc im talking about looks like this but only this is a roll lock style...
The part number for the ones i used was (3M SandBlaster 9682)
but you'll only need the green disc not sure what the part number is for it individually
Old Apr 12, 2012 | 06:31 PM
FueledSoul's Avatar
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
69 Six Pack
Oct 5, 2015 07:51 PM
z28addict8490
Aug 7, 2015 08:48 PM
