Best way to remove/redo rust spots?
Old Sep 7, 2011 | 12:14 AM
al3x751's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6
Hi, I have trolled here for a why just lurking until one day when I can actually put money into my 92 rs and I think tomorrow I am going to start giving it the care such a nice care deserves. Whats the best way to remove rust spots/holes. Let me know what you guys did and ill get some pictures up soon of some of the spots that I want to fix.
Old Sep 7, 2011 | 08:45 AM
Stroxell78's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 373
Re: Best way to remove/redo rust spots?
Most of the time you will need to cut all the rust out and put new metal in. but if you just have a small spot. you can sandblast it. and just use some touch up,as a fast fix. but in most cases you will need to cut it out
Old Sep 7, 2011 | 09:12 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
pics would help, but if it is bad which most rust is id cut it out. I had to do that with alot of my t-top area.
Old Sep 7, 2011 | 09:52 AM
al3x751's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6
I'm gonna go get some picture now. When I work on my 86 Monte Carlo for racing, looking nice isnt what the end goal is in, so im not sure I know how to fill in rust with metal and make it look nice. lol just cut a piece of metal big enough then weld it over the cut out whole and sand it down to smooth it out? We usually just weld and leave it cause its not going to look pretty anymore. Pics in a few minutes. EDIT: First picture on left is driver side tower, second is the hatch back below the fin thing. I also have it on the rear wheel wells(go figure) and I am concerned because it is a A-frame car, about rust behind the wheels on the body where it goes up and over the axel. how would I go about fixing rust in there?
Attached Thumbnails Best way to remove/redo rust spots?-664845267_2377176532_0.jpg   Best way to remove/redo rust spots?-664845430_2377177074_0.jpg
RedLeader289
May 28, 2019 01:47 PM
Fireslash
Apr 11, 2016 06:43 PM
bigjay89gta
Oct 15, 2015 08:04 AM
LC2 TECH
Oct 13, 2015 11:53 PM
aaron7
Sep 30, 2015 09:15 AM
