To rattle can or not to rattle can....that's the question.
Old May 5, 2012 | 06:11 PM
  #51
86blackbetty's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305/V8
Re: To rattle can or not to rattle can....that's the question.
Originally Posted by haps
Rolled paint over rattle-canned primer. Won't last long and you won't be able to put a decent job over it unless you strip that inferior stuff off.
its lasted a year well worth the money already. ANd like i said not difficult to remove..someone lazy or someone who hasnt done it says that. I myself alone would be able to remove this "inferior stuff" in a day. i leave it at that as i have the mayweather cooto fight to look forward too...take car guys and good luck firebird mess
Old May 5, 2012 | 07:50 PM
  #52
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
A day? Damn, that's awesome. You should come and help me strip mine. Today I spent 3 hours on just the doors.
Old May 18, 2012 | 08:47 PM
  #53
Firebird Mess85's Avatar
Car: 85 Firebird & Grand Prix GXP
Engine: LG4 305 (originally 2.8L V6)
Axle/Gears: 10 bolt 3:43 Open Diff.
Update:
http://youtu.be/wdjJqr2-m40
Just have the door jams left to sand. I found bondo from a previous owner that I didn't know existed till last week.. I've got all the rust spots ground down to metal but they flash rust very quickly so I need a solid day to resand them. Then I have SEM Solve to clean the car with and after that the metal spots are getting treated with Ospho (had to search for days and drive 22 miles to get it). Ospho is supposed to set overnight and then it gets wire brushed and canned self etch primer goes over the metal. Then it's on to filler and primer.... WOW...I thought I was closer to painting before I typed all that.
Old May 18, 2012 | 09:33 PM
  #54
Jeffs82TA's Avatar
Your wasting your time rattle canning/rolling ... I thought about this but then just bought a spray guy and 24.95 a quart autozone duplicolor paint. I used a very worn out 3hp 15 gallon compressor and 32.95 paint gun.
sanded corvette with is 220 then primed and blocked with 400
Old May 18, 2012 | 09:43 PM
  #55
Maybe I need to start a new thread. I'm not rattle canning it. I've decided against it. I have an HVLP turbine sprayer I'm using. The only rattle can thing I'm doing is the self etch primer on the few metal spots I have sanded down. I was going to use that Paint Shop stuff originally but this thread had so much info against the lacquer stuff that I've decided to use a single stage black urethane paint.
I will say that your vette came out great. It looks like there's no orange peal at all.
Old May 18, 2012 | 09:56 PM
  #56
Jeffs82TA's Avatar
Thanks ... Here it is when I first bought it for 1500.00 ... I bought the car after twin_turbo bought my black and gold 82 Trans Am
will be doing doors and hood later
hood/doors/are white replacements which is why they don't match but from doors back and front bumper I painted to get it one color for time being.
ZZ3Astro
Aug 13, 2019 12:57 AM
jrdturbo
Mar 31, 2016 02:58 PM
corey8084
Sep 17, 2015 02:56 PM
GouldyGTR
Sep 7, 2015 09:05 PM
Ian Irvine
Sep 4, 2015 08:08 AM
