Japan rear fender flares?
Old Sep 28, 2011 | 09:16 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Anybody know if they are still available in Japan anywhere? Or where I might be able to get a set? I've got a 1995 Firehawk spare rear axle & wouldn't mind using it, but my tires would set out past the top of the fenders, with my aftermarket wheels.
Old Sep 28, 2011 | 09:46 PM
Car: GTA
Re: Japan rear fender flares?
I don't want the front flares, just the rears. But if buying the complete set is the only way to get the rears, I just might if the price is right.
Attached Thumbnails Japan rear fender flares?-p1010021.jpg   Japan rear fender flares?-24c94250e254a7.jpg
Old Sep 28, 2011 | 10:56 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
wow,thats weird....never seen or heard of these.
Old Sep 29, 2011 | 11:45 AM
h1-vltg's Avatar
Car: 91 Camaro Z28
Engine: LS3
Transmission: 6 Speed
Axle/Gears: 3.71
me too.
Old Sep 29, 2011 | 12:24 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Here is another option https://www.thirdgen.org/forums/body...one-phase.html
Old Sep 29, 2011 | 07:03 PM
Car: GTA
Originally Posted by camarotucker
I knew about those already. But I asked about the much easier option for a reason. MUCH cheap. They wanted like $2000 just to do my outer panels, not even then inner tub sections or LCA mods Neal got. and heard many bad things about how "well" they fit & how much work is needed to make them fit. And with the way Firebird taillights fit & the panel in-between them, you can't just more the lights outwards. There would be big gaps between the lenses & center section.
Before I did the steel route, I would get the IMSA pieces from that cover the whole quarter panel. http://www.showcars-bodyparts.com/firebird8292.html
Old Sep 29, 2011 | 09:09 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
http://www.bodykits.com/AIT-Racing/F...ENDERS/619817/
http://www.bodykits.com/chevy/Camaro...Fender-Flares/
there was a thread on here but I couldnt find it, but here are the links
Old Sep 29, 2011 | 09:36 PM
Car: GTA
I saw those awhile back, but I'm not willing to spend $170 on "Maybe this will fit?" I'm sure they would be a hassle to return. Consider those a last ditch choice.
Old Sep 29, 2011 | 11:18 PM
Car: GTA
I just checked my car & for flares like that to fit along the stock body line it would need to span 24.5". Those are only 19", so wouldn't quite fit right.
Old Sep 30, 2011 | 05:00 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
FIBERGLASS VISION WIDEBODY KIT
Ask for just a set of rears.........
Old Sep 30, 2011 | 08:50 AM
Car: GTA
Thanks for the suggestion, but I asked about what I want, not for suggestions on how to cover wide tires.
I already posted a link to those before you even suggested them, after somebody else suggest Neil's quarter panel mod. IMSA = Widebody
I have already talked to them & they will sell just the quarters & either I can buy just the rear portions of the ground fx that flare out to match & blend those in with my stock pieces, or the complete ground fx pieces that fit to the flare rear quarters.
Sorry guys, but I asked about where to get what I want. Not for suggestions on other products.
Old Sep 30, 2011 | 12:07 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
If there was anyone in the states selling them, we would know
Could spend the money to have a glass shop make a mold and sell 10 sets to cover your cost.
The molding is what cost up front, they will sell easy.
FYI copy the black/green car, the ones on the red one look just awful.
Old Sep 30, 2011 | 03:42 PM
AmorgetRS's Avatar
I don't think the black/green car has the flare on it, I believe the car was originally green, painted black without taking the flare off, then the flare was removed
Old Sep 30, 2011 | 04:06 PM
Car: GTA
This pic show them better for you?
Old Sep 30, 2011 | 04:33 PM
AmorgetRS's Avatar
I can see the pictures just fine, Stephen. If you look at the red car you will see that there is a noticeable lip on the flare, both at the top and where it meets the body line on the side. The green/black car doesn't have that.
Old Sep 30, 2011 | 05:33 PM
one92rs's Avatar
Car: SOLD!!!!!
looks like something that should be on a truck.
Old Sep 30, 2011 | 08:46 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Red car ones just have way to heavy of a lip where they meets the body.
Like said above, they could be uni fender flares off some truck, they tend to have those hard lip bulky plastic look.
which i have actualy looked into, finding fender flares of a truck with a similar arch.
Old Sep 30, 2011 | 08:52 PM
Car: GTA
I have no idea if the red & green car have the same flares (brand/maker) or if they are totally different.
What I do know is that I would not simply slap mine on. They would be mounted secure, molded in, then everything repainted, so it looked like the car was built that way, not just an added-on piece.
The Widebody/IMSA quarters would be very nice & a preferable choice, but also cost more.
Old Sep 30, 2011 | 11:01 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Wow. Thats ugly. But if it suits your taste, then go for it. Maby a metal fabricator can do something like that for you. I know its possible. Just look at American Chopper, Jr vs Senior. Rick sometimes bends sheet metal into shapes that I thought where made stamping or by pouring molten metal into a mold.
Old Sep 30, 2011 | 11:28 PM
Car: GTA
I'd think that once they were molded in & painted, they'd be more like Niel's widened quarters. You look at them & know something is not quite normal, but your not sure what!
Old Sep 30, 2011 | 11:33 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Could probably pull a myth buster and carve and shape what you want from foam and then glass over it, leaving the foam inside. [not mold making]
Old Sep 30, 2011 | 11:38 PM
Very good point and thought. Remember the RS that they used to make that funky Batmobile? Man that got under my skin.
Old Sep 30, 2011 | 11:42 PM
I'd think that once they were molded in & painted, they'd be like Niel's widened quarters. You look at them & know something is not quite normal, but your not sure what!
Yeah. thats true. i saw a "Paddle" rear view mirror 3rd gen some where on the boards. When I heard Paddle mirror, I was like what the heck are these guys talking about. Then i saw the picture and I was like "What the BEEEEP! So I know what you mean by "not sure what".
Old Sep 30, 2011 | 11:50 PM
Car: GTA
I had been thinking wondering about that & wanted to investigate actually making them as molds that could be reproduced again, but I'd hafta figure out the mold-making process. I'd seen it in videos, but that certainly doesn't equal understanding how to do it.
Old Oct 1, 2011 | 12:06 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
though not talking about making molds, you carve foam into the flare for each side,[make 2] you then glass over the foam onto the car, foam stays inside as filler.
Would be less work then trying to reshape n mold those red car ones.
now if you want to go all out n make a mold......
http://www.fiberglassforums.com
Old Oct 1, 2011 | 12:15 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
But it worked really well, beyond being corney.
Old Oct 1, 2011 | 12:21 AM
Car: GTA
I dunno whether to thank you for the link, or be mad at you for complicating my life because I will be reading that site a lot now!
I knew the foam part of just making parts on the car & leaving them there. It was the mold part of reproducing multiple parts that thought about learning. I figured if I successfully made some good ones, others might be interested in buying some, so that I could at least recoup my $ invested in making my own set.
Old Oct 1, 2011 | 12:33 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
"ponte"
http://www.fiberglassforums.com/showthread.php?t=1850
use to be a good thread about "milk shake" too but its broken now.
http://www.fiberglassforums.com/show...?t=3219&page=2
customblackbird
Aug 15, 2021 10:16 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
deracer
Apr 11, 2016 12:04 AM
kah992
Aug 19, 2015 02:55 PM
kyleb24
Aug 15, 2015 08:24 AM
