1986 t/a lower air deflector
Old Oct 8, 2011 | 12:48 AM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
i have a 1986 t/a that i bought that never had the radiator lower air deflector it mounts between the radiator cross mounts and lower part of the front bumper. all mine had was the side rubber on the radiator. i went to the junkyard and got the pieces its actually 2 but becomes one once it is installed i forgot how it mounts it was of a '88 model t/a if any body can check how its mounted or if requires some sort of screw clips i know some of those need the plastic like buttons that have curved ribs on it. i will post pics on it to give you an idea of what i mean or if you know post some pics for me so i can reference them and install it on mine
Attached Thumbnails 1986 t/a lower air deflector-bottom.jpg   1986 t/a lower air deflector-bottom2.jpg   1986 t/a lower air deflector-bottom3.jpg
1992 Trans Am
May 10, 2023 07:19 PM
87iroctheo
Dec 4, 2016 11:47 AM
Pilotrick50
Sep 2, 2015 12:48 PM
Dialed_In
Aug 20, 2015 01:45 PM
