Third Gen Firebird stuck headlight
Old Nov 22, 2011 | 07:50 PM
Nicks'89-5.7GTA's Avatar
Car: 1989 Pontiac Trans Am GTA
Transmission: 4-Speed Automatic
My left front pop-up headlight is stuck down- the motor doesn't even turn. When I turn the motor by hand , the headlight moves up about half an inch before stopping. Is there anyway I can manually open it until I can find the problem? i just need to be able to use the headlights.
Old Nov 22, 2011 | 09:59 PM
Mailman818's Avatar
Car: 89 firebird bone stock for now
Engine: 2.8L V6
Axle/Gears: B.W 9Bolt 3.27 Posi
Re: Third Gen Firebird stuck headlight
when i had that problem this is what i did. i lifted my hood then i flipped the headlight switch and quickly ran to the bad light and helped it up. then i locked the headlight in place by pushing the moving arm all the way up so it wont go back down. then unplugged the motor.
if u need a pic i could go outside right now and take a few pictures to show u what i mean
it allows you to still flick your lights on at any time.
Old Nov 22, 2011 | 10:17 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
It sounds like you probably need to change the bushings in your headlight motor. We have bushing kits available if that's the problem. Here's a link if you're interested.
http://thirdgenranch.com/-strse-186/...tor/Detail.bok
Old Nov 26, 2011 | 02:39 PM
Just found the issue- the plastic lip on the light was stuck underneath the bumper. Just had to pry it up, now it moves by hand. not sure if the motor works, since my fuel line is loose near the tank and gas spray out as soon as the key is turned. That i can fix myself though. Thanks for the help!
Old Dec 2, 2011 | 09:59 PM
Mailman818's Avatar
Engine: 2.8L V6
Ha i remember when i tried my lights for the first time and the same thing was happening. the driver side wouldnt go up and sure enough the plastic bezel was under the bumper. but yea if your motors dont "work" make sure when you turn the cap up top that the metal peice that moves the headlight spins so you know just to replace the bushings in it. you could get them from ebay or thirdgenranch too or other places.
Old Jun 29, 2024 | 09:06 PM
87Red&Gold's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7
Hey how’s it going? I have a 1987 trans am gta and I am trying to replace the drivers side headlight motor and my headlight won’t even manually open
Old Jul 1, 2024 | 07:05 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
try pull up with light by the bezel with light to medium force as you turn the ****
1992 Trans Am
May 10, 2023 07:19 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Fronzizzle
Aug 19, 2015 01:36 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
tnrednneck
Aug 13, 2015 08:57 AM
