Can this fender be adjusted?
Old Nov 24, 2011 | 10:59 AM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
This is one of the small items that bug me on this car. It is a 79,XXX mile car but this fender is bowed out. Can I adjust the bottom bolts and bring it in a bit? Can I space out the door with shims to bring it out? What is the best way to attack this?
Thank you in advance.
Old Nov 24, 2011 | 11:07 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Can this fender be adjusted?
Look underneath it, where the factory jacking place is.
If it's bent, that **may** be the cause. Sometimes people use a floor jack in the area to raise the car.
There is a thread how to fix it, but I don't recall the title.
Old Nov 24, 2011 | 11:28 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
maybe this is it
https://www.thirdgen.org/forums/body...ng-damage.html
Old Nov 24, 2011 | 01:26 PM
TheGr8erG00d's Avatar
My car has the same issue on the same fender. It's from the PO placing a jack under it in the wrong place.
Old Nov 24, 2011 | 03:03 PM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
This was the way my fender looked on the drivers side....Its the pinch weld underneath the car. Just like everyone mentioned--the prior owner jacked it up in the wrong place and the fender moves as a result. Fix the pinch weld underneath the car and the fender will go back to where its supposed to be.
Here it is after the repair:
Old Nov 25, 2011 | 04:26 PM
rarebmx's Avatar
Thank you all. I will try this maybe tonight. That little stuff that can be fixed drives me nuts. Now that the issue seems fairly simple I am much happier. I do appreciate the time to look up a link for me and the replies.
Old Nov 25, 2011 | 08:13 PM
rarebmx's Avatar
Thank you all for the help. Wow, that was not too tough, not perfect yet but VERY close. I will get my big floor jack out and work on it some more but it is almost perfect now. Wow - I'm making progress on this thing. Glad for this forum!
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
jovibuilt
Oct 18, 2015 08:12 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
