Hinge Pins
Old Nov 27, 2011 | 08:42 PM
racewrench's Avatar
Car: 1992 Camaro RS
Engine: 305 (406 swap coming)
Hinge Pins
hey all, I have a 92 RS and my doors are hanging low. I see that the lower hinges have replaceable pins and bushings but the top hinge looks different, they don't look like they can be rebuilt. how do I fix them, is there something I'm missing?
Old Nov 28, 2011 | 03:23 AM
85TransAm406's Avatar
Car: 1985 Trans Am
Re: Hinge Pins
this is the kit I have. The upper hinge rebuild kit is somewhat more complicated to install than the lower, but not too bad.
http://www.hawksthirdgenparts.com/ca...werpinkit.aspx
Old Dec 4, 2011 | 04:12 AM
streetpro's Avatar
Car: 1987
Engine: 454
Re: Hinge Pins
racewrench are those the pins to use when you have to pick your door up a little
to make it close right?
Old Dec 4, 2011 | 05:42 AM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Re: Hinge Pins
streetpro, if worn hinges are the cause for your sagging door then that kit should make them right with little to no adjustment to the door.
Old Dec 4, 2011 | 02:55 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
Re: Hinge Pins
I installed the hinge kits and the doors close like new.....I would check the area around the hinges where they are welded to the door for rust just to be safe.....I picked out some seam sealer in this area and found rust
Old Dec 4, 2011 | 07:08 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Hinge Pins
I need to do the same but is the hinge pin replacement enough? Does the striker bolt also need to be replaced if it's worn? Do the hinges provide all/most of the support or does the striker also help support the door?
Old Dec 5, 2011 | 07:15 AM
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Re: Hinge Pins
Hinges do most all of the support. Striker should be replaced if worn, can cause door to rattle when shut or be hard to shut.
InfernalVortex
Apr 20, 2021 11:31 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
chuck13
Interior Parts Wanted
Sep 22, 2015 11:19 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
