Frame Measurements
Old Dec 11, 2011 | 08:09 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Frame Measurements
My car was involved in a 70MPH collision two years ago in which it T-boned/sideswiped a Silverado. It did not hit head on; it caught the truck with the passenger side front corner at an extreme angle.
Other than the fender and front bumper There does not appear to be any damage but I believe the frame is tweaked. Does anyone have the frame measurements and reference points to check the frame from the firewall forward? I need to know whether to put it on a frame machine before starting the bodywork.
Old Dec 12, 2011 | 05:46 AM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Re: Frame Measurements
I have a copy of the underside measurments if that's what you need. I should be able to get underhood measurements as well if you need them. Send me a pm with your e-mail addy and I can send you what you need. Don't want to post them as they are leased so to speak.
Old Dec 12, 2011 | 12:10 PM
RagRoc's Avatar
Car: 88 IROC Convertible
Transmission: M5
Axle/Gears: 9-bolt 3.45
You can also try measuring diagonally from the core support to the cowl using the same reference points for each side. They should be the same if there is no damage.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
