How Hard Would It Be To Do This?
Old Dec 16, 2011 | 11:35 AM
jameecrockettRS's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI (5.0L)
Transmission: 4 speed automatic
I was browsing camaro images on google, and came across this;Name:  CoolCamaroHood.jpg
<br>
How Hard would this be to do? Cost? Etc?
Old Dec 16, 2011 | 12:37 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Re: How Hard Would It Be To Do This?
Get your hands on a Daytona hood, cut out the sections underneath the louvers and cut some decent plexi/lexan panels to match. Then all you gotta do is fabricate a gasket and fasten them down.
Me? IF I were to do something like this I'd probably try to source panels made from glass instead of plexi/lexan.
Old Dec 16, 2011 | 12:39 PM
Car: 1989 Camaro RS
Yea. I agree on the glass vs. plexi/lexan because I am sure that road dirt/sand would rather easily and rather quickly scratch the plexi to hell.
Old Dec 16, 2011 | 12:41 PM
crazymonkey16's Avatar
Car: 1990 Camaro RS
Engine: L05 TBI
...why would you do glass, if I may ask? It'd be harder to shape, harder to drill holes to fasten without shattering, and it'd weigh more... would plexi really scratch that easily?
Old Dec 16, 2011 | 12:42 PM
Car: 1989 Camaro RS
Definitely due to the scratching effect of the road dirt. as stated above. IF I were to use plexi, then I would have to make some kind of cover for driving, and take them off at shows, etc.
Old Dec 16, 2011 | 12:47 PM
Car: 1989 Camaro RS
Perhaps I might do something similar to a Cowl or Big Block hood, Rather than the Daytona. I seem to only be able to find bolt on versions of it.
Old Dec 16, 2011 | 12:49 PM
Car: 1985 Z28
Yes. Plexi is very easily scratched. I'd give 6 months tops and you would be seriously wishing you had opted for glass.
Yeah glass is a bit heavier, but we're not talking a windshield or hatch glass here. The difference would be negligible.
If taking the glass route, You'd probably have to have a specialty or fab shop do it up for you IE take them a louver and tell them you want it cut in that shape and where to drill the holes.
I'm sure they sell glass cutters, but I've never dabbled with them before. I HAVE however, had experience with drilling holes in glass (Don't ask me what for unless you want me to make your day). All it takes is a glass drillbit, some running water, patience and a delicate hand.
Old Dec 16, 2011 | 12:51 PM
Car: 1989 Camaro RS
Ideas on Cost? minus the hood of course.
Old Dec 16, 2011 | 01:10 PM
Car: 1985 Z28
No idea. I believe it was around $5 - $10 for the bit. You'd also need the glass cutter and some glass, and I have no clue how much those go for.
You're also gonna need a pretty fresh engine bay or you're gonna look like a tool with this mod.
Old Dec 16, 2011 | 03:48 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
glass cutters are a couple bucks at a home supply store or hobby shop. cutting glass isnt easy but if you take your time and do it right you can get a clean break (you dont cut it, you score it and then break it along the score line). you need a steady hand and patience. id personally go with a scratch resistant lexan instead of glass. theres a few companies that make scratch resistance lexan. it holds up better on road use, but isnt scratch proof.
Old Dec 16, 2011 | 03:50 PM
Car: 1989 Camaro RS
Glass isn't scratch proof either. I would like to also say that I intend on doing some engine dress up, and would like to know where to start.
Old Dec 16, 2011 | 04:01 PM
travis401's Avatar
Car: 91 Camaro RS
glass is a lot harder to scratch from road debris though. the scratch resistant lexan isnt as hard to scratch, but harder than normal plexi or untreated lexan.
Old Dec 16, 2011 | 09:53 PM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
Why wouldn't you want to use poly-carbonate? Just curious.
Old Dec 17, 2011 | 06:08 AM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
I'm glad to see people are stealing my ideas and work and copying it.
Old Dec 17, 2011 | 09:44 AM
travis401's Avatar
Car: 91 Camaro RS
lexan is poly carbonate?
Old Dec 18, 2011 | 12:00 AM
Slash's Avatar
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
Alex is the first to make this Hood, All Custom.
NYTHIRDGEN Representin'
Old Dec 18, 2011 | 12:59 AM
Shadow Z's Avatar
Car: Lots of 'em
Take it as a compliment man.
Old Dec 18, 2011 | 04:57 AM
Pajjen's Avatar
Car: Pontiac Trans Am GTA -87
Engine: 5.7 TPI
There is a material that doesent scratch as easy as poly-carbonate and it is also much more durable, it doesnt cost much more than the poly-carbonate.
I dont remember what the name of that "glass" is but if i see it i can tell you.
I know that they sell it around here to excavators and such things.
Old Dec 18, 2011 | 08:32 PM
akanitro's Avatar
lexan is one form of poly carbonate. I was thinking of a similar material called polymethyl-methacrylate (acrylic).
Old Dec 19, 2011 | 01:16 AM
Pajjen's Avatar
Engine: 5.7 TPI
now i know what its called here. Hammerglass is the name.
Old Dec 19, 2011 | 06:22 PM
Charged350's Avatar
Car: 87 IROC Z28
It's only a compliment when it's done right, the proper way so it looks right, many have tried since I invented this hood years ago and all have failed, some worse then others. The picture above is one of the better attempts, even tho it's still just screwed into the hood. I mean c'mon, put some effort in it.
Old Dec 19, 2011 | 06:48 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I deff wouldnt use that hood to start with. (i'm just not a fan)
Id use/make a stock 86-7 ish carbon fiber/ fiberglass hood .
Neatly cut the holes a half inch smaller than the than the louver.
Id make the the new covers out of scratch resistant lexan and heat the sides after cutting so they are nice an smooth.
I wouldn't screw them down either.
I'd use a 1/16inch thick bead of windshield urethane on the backside so it only shows a nice even half inch wide strip of black urethane around it.
You could use glass but its a pain to work with (for this app), rocks will scratch/break it and you would want to use safety glass. Just incase. My dad has owned a stained glass studio since I was a kid and I've been around glass since.
Old Dec 19, 2011 | 07:59 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Well then enlighten us. Post some pics.
Old Dec 20, 2011 | 10:44 AM
Charged350's Avatar
Car: 87 IROC Z28
You can find the thread of my build on the forum. I just don't get why people gotta copy, be original come up with your own ideas.
Old Dec 20, 2011 | 10:49 AM
Charged350's Avatar
Car: 87 IROC Z28
Old Dec 20, 2011 | 10:55 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
https://www.thirdgen.org/forums/body...d-hood-im.html
Old Dec 20, 2011 | 04:52 PM
Car: 1990 Camaro RS
Engine: L05 TBI
...I just don't get why people gotta copy, be original come up with your own ideas.
Not to be a pest, but... doesn't that just tell you how good an idea it is? I mean, people are trying to copy it because it looks nice, not because they've got a personal grudge against you or something. *shrug* but that's just my .
Old Dec 20, 2011 | 05:22 PM
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
I wouldn't use glass to begin with. First off, the difficulty in fabbing it is pretty steep. Secondly, you'll want some form of spalling shield on the motor side of the glass which means you're buying some form of laminated glass that is just as costly as the more advanced lexans out there. The most common scratch resistant lexan I've used is MR-10 lexan. Unless you're using MR-10 in a windshield application & DD (think use of wipers fairly regular here), MR-10 is pretty good.
Old Dec 20, 2011 | 05:57 PM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Perpsex is fine.
The windscreens of small planes are perspex. They typically fly around at 150 miles an hour and last for more than 10 years.
Old Dec 20, 2011 | 06:40 PM
lt1zr28's Avatar
I'm not sure how wanting to do this is stealing someone elses idea.If GM already did
the hood of a vett.Seems like I saw that in someones thread.
Old Dec 20, 2011 | 07:08 PM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
Originally Posted by peterc005
Perpsex is fine.
They make a polish specific for Perspex as well, removes crazing and other small scratch's.
Old Dec 20, 2011 | 07:29 PM
92 BBC Z's Avatar
right, he did say 'think zr1' when he was making his.
Old Dec 20, 2011 | 09:00 PM
Charged350's Avatar
Car: 87 IROC Z28
Look at the zr1, then look at my hood, does it look like a copy? No, now look at mine and look at the one on top, does it look like a copy, yes. That's all.
Old Dec 20, 2011 | 09:44 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If you don't want your ideas taken, don't share them.
Old Dec 20, 2011 | 11:45 PM
travis401's Avatar
Car: 91 Camaro RS
you do something unique and cool and of course people are gonna copy it. and just because you were the first to do a see through hood on a 3rd gen doesnt mean it hasnt been done a thousand times before on other cars. you just took someone elses idea and made it your own.
Old Dec 21, 2011 | 09:39 AM
Charged350's Avatar
Car: 87 IROC Z28
I don't mind if people try to use my idea and modify it and make it their own, but a carbon copy is a bit too much IMO, and if you are doing that, then make it look as good if not better then I did, evolving the mod into a better one, not hack jobs like I've seen and certainly not using screws to attach it to the hood, you get what I'm saying...
Old Dec 21, 2011 | 11:17 AM
Car: GTA
Maybe you should sue Chevrolet for stealing YOUR idea & building the ZR1 with it?
Old Dec 21, 2011 | 11:50 AM
Charged350's Avatar
Car: 87 IROC Z28
They already paid out for that.
Old Dec 21, 2011 | 12:15 PM
Car: GTA
Actually, you already said that you copied the idea from them.....
it wasnt a lexus..it was a turbo g37...
and all ive got to say is think about the new zr1...maybe that will give you an idea about whats gonna happen
Old Dec 21, 2011 | 01:06 PM
92 BBC Z's Avatar
I think using fasteners is better, more forgiving. If you ever need to remove them for whatever reason, you could do it no prob. But not so easy if sealant or epoxy is used. If you paint the screw heads black, they become less noticable. But you could also fasten them from the underside. With fasteners the hood becomes 'adjustable' and have the ablity to custom change on-the-fly so to speak.
Old Dec 21, 2011 | 01:32 PM
TTOP350's Avatar
Clear see thru hoods are a brand new idea.. Oldsmobile had TEN different "see-thru" hoods available between 1949 and 1953.
1949 Olds see thru hood. Granted this was a display unit but not a "new" idea by any strech..
http://www.ebay.com/itm/Hood-Oldsmob...sories&vxp=mtr
Old Dec 21, 2011 | 01:51 PM
  #42
Car: GTA
Why stop at just a hood?
http://twistedsifter.com/2011/06/193...***-ghost-car/
  #43
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by TTOP350
Granted this was a display unit but not a "new" idea by any strech...
Can't be... it just can't be!
Definitely not a new idea, but Charged gets the credit for that particular hood though...
Old Dec 21, 2011 | 02:03 PM
  #44
travis401's Avatar
Car: 91 Camaro RS
ive seen the see thru car pic before. i like it.
Old Dec 21, 2011 | 08:27 PM
  #45
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
lol maybe you should patent your idea otherwise quit complaining
Old Dec 23, 2011 | 03:41 PM
  #46
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
He did say in the original thread that there is a TM with a circle around it. That means he did patent it.
I had not seen this before now but I do like it. I gave a similar idea to a friend when he was thinking of getting another hood for his Z28. However I had not thought of this.
To Charged350 I give you a big thumbs up on the original.
Old Dec 23, 2011 | 08:00 PM
  #47
Pillsbry10's Avatar
Then file a lawsuit lol
Old Dec 23, 2011 | 08:16 PM
  #48
Car: GTA
He wants us to believe that he already sued GM, won & GM paid him.
I wanna see his Patent or Trademark for the hood.
RedLeader289
May 28, 2019 01:47 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
loud91rs
Oct 5, 2015 10:05 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
