Broken ground effect stud
Old Dec 29, 2011 | 12:31 PM
lonesomeloser's Avatar
Car: 1983 Z28
The stud was rusted and broke off. Anyone make the metal brackets that attach the ground effects to the car?
Old Dec 29, 2011 | 05:53 PM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
Re: Broken ground effect stud
I dont know if anyone manufactures them but i can build you a set... just send me the measurements and I'll let you drill your own holes if you'd like or i can drill them... let me know
Old Dec 31, 2011 | 06:39 AM
GOATS2QUICK's Avatar
Car: 89 trans am / 67 gto
Engine: 350TPI
Transmission: AUTO
Axle/Gears: 3.27 9 bolt
the studs are carrage bolts. you can tap out the old broken ones, and install new ones. i replaced all mine while the ground effects were off my car while repainting.
you can buy them at home depot, or lowes.
Old Jan 1, 2012 | 06:01 PM
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
If you need info on the stud, I had to find a new stud nut and have it all on hand. The stud is an M7-1 (7mm in diameter, 1 thread per mm of stud) and its about an 1"-1.5" or so in length. The nut GM used to fasten the GFX to the rocker is an 11mm wide flange nut. The nut is not an on the shelf item anywhere. You'll need an 11mm hex or lock nut, 5/16" large washer, and 7mm or similar sized lock washer to secure the GFX to the rocker.
Hotrodboba400
Dec 10, 2019 07:07 PM
skeltor
Feb 2, 2016 10:37 AM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
billybob6110
Sep 23, 2015 01:30 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
