Removing nose piece
Old Jan 2, 2012 | 09:40 AM
Jakes92RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1L
Removing nose piece
What's the easiest way to remove the front nose piece and gfx on a 92 rs? I'm wanting to paint my head light pocket and my grill. Also repair a couple cracks on the front with bondo or some type of epoxy.
Old Jan 2, 2012 | 10:33 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Removing nose piece
youll need to disconnect the front chin spoiler from the fender first and under the core supprt first, then take the black plastic cover off between the core supprt and bumper cover and unbolt the headlight support brackets from either the headlight bar, or the core support. then you can remove the front bumper cover. its held on to the fenders with 4 nuts per side. easiest way is to get under the car, remove the plastic peices in the way, and reach up to the nuts with a 10mm socket. the headlight bar will come off with the nose and can be seperated after wards.
ktthecarguy
Jul 5, 2020 11:46 AM
Vintageracer
Jan 10, 2020 05:33 PM
Glowsock
Aug 26, 2015 12:28 AM
theshackle
Aug 22, 2015 06:52 PM
3rdgenparts
Aug 8, 2015 07:09 PM
